Old 06-18-2008, 01:26 PM   eBay Motors   #1 (permalink)
Sn@ke_Doctor
Sn@ke_Doctor's Avatar
Wire Harness Failure TSB
Has anyone heard of the wiring harness going to the injection control module on the passenger side of the engine having a TSB in reference to wires grounding out on a bracket or something. I just had new injectors (RECALL WORK) less than 150 miles ago. The truck just died yesterday and would not crank back up. The stealership assured me that this was an existing problem prior to their work last week. It may just be me but this sounds like a bunch of crap. I was wondering if any one of you have heard of this before.
IF FIREFIGHTERS WENT TO HELL...WE'D JUST PUT IT OUT!!!
02 GMC 2500 CCSB, 4x4 BONE stock LB7 except a K&N drop in OE replacement. Chrome Tri-steps. Cowl Induction Hood. ARE Topper, Sony Sound
Sn@ke_Doctor is offline   Reply With Quote
Old 06-18-2008, 01:49 PM   eBay Motors   #2 (permalink)
K9Duramax
They supposedly did it to mine, there was no problems- just did it for reassurance to prevent (dealership actually being nice). From the way that I understand it, it is a loom of wires that runs by the alt (correct me if wrong), can wear through and cause problems, supposed to be pretty common though.
'05 CC/SB, Stock with the exception of KN Cold Air Intake, now added PPE Tuner (more to come......), damn cat finally fell off, finally finished off the rest with 4" SS Magnaflow
K9Duramax is offline   Reply With Quote
Old 06-18-2008, 04:35 PM   eBay Motors   #3 (permalink)
Sn@ke_Doctor
Those are the wires. It just seemed kinda coincidental to me. The main reason I believe that is they initially quoted me $225 to fix this. Less than 1 week after their DIESEL TECH had his beaters all over them replacing my injectors. Maybe its just me...if there was a "problem" in this area I would have inspected it when I had it all apart to keep myself looking guilty of sabotage. These are harsh words but i am pissed. I didn't mention another tow truck fee did I.
Old 06-18-2008, 07:24 PM   eBay Motors   #4 (permalink)
bob213
bob213's Avatar
There's actually 2 problems. The bracket by the FICM next to the alternator will wear thru and ground out your wires. Place a piece of heater hose around the loom and re-tiewrap it to the bracket.
2. There is a TSB for the NO. 2 and 7 injector connections. They have too much tension on them and eventually become loose. I read on "Diesel Place" about poking thru the connector tangs with an ice pick to make them have a better connection. Search "ice pick trick". There is a factory repair with two new connectors and brackets but sounds like you have to be broken down before they will repair it. They have extended the warranty to cover this issue. Still may be a $100. deductible.
2005 GMC Crew Cab SLT 4X4
4" MBRP turbo back
Diablo Sport Predator/EGR Blocked
BD Exhaust Manifold
AutoMeter UltraLiteII Pyro Gauge
Induction Overhaul Kit by "Killer Bee" with
True CAI by "KillerBee" THANK YOU!!! Michael...
bob213 is offline   Reply With Quote
Old 06-19-2008, 05:12 PM   eBay Motors   #5 (permalink)
BigGrnJeepTug
BigGrnJeepTug's Avatar
Just did a write up-ish on it. I posted some pics. Hope it helps.
http://www.duramaxforum.com/forum/04...-mode-fix.html
05' LLY CC/SB, PPE Standard, MBRP SS 4", BD Power Manifold, Autometer Phantom 2 Pyro and Boost, Kennedy fingered n plugged, cat grew legs, Belltech 1/3 drop, Michelin LTX M/S 265/75/16, Homemade 2-stage Water/Methanol w/ 220psi pump.
Rock it till it sounds expensive!
BigGrnJeepTug is offline   Reply With Quote
Old 06-22-2008, 06:48 PM   eBay Motors   #6 (permalink)
duramaxdr
The two bulletins you are referring to are for the LLY duramax 04-05 model year. The LB7 did not have problems with the injector connectors nor the wires chaffing around the FICM
duramaxdr is offline   Reply With Quote
Old 06-22-2008, 07:25 PM   eBay Motors   #7 (permalink)
bob213
bob213's Avatar
You are correct......It is LLY's only.
4" MBRP turbo back
BD Exhaust Manifold
Old 06-22-2008, 07:48 PM   eBay Motors   #8 (permalink)
duramaxchris06
duramaxchris06's Avatar
before i have to worry about it....have you ever heard of it doing this on the LBZ?
2006 Chevy Duramax LBZ 3500HD CC Dually LT3 4X4
Allison 6-speed automatic. Leather Heated Seats, Bose XM Stereo w/6CD changer
4" MBRP turbo back exhaust, 5" pollished stainless steel tip, & Turbo Resonator plugged!
Edge Juice with Attitude.
Painted front bumper, bowtie emblem, tow mirrors, and fender flares, Cadillac style handles, Recon Fire and Ice light bar, clear cab lights and 3rd brake light.
2008 emblems
B&W turnover ball
Michelin LTX A/S 265/75/R16, 2" spacers
Lost Kitty! & EGR Blocked
duramaxchris06 is offline   Reply With Quote
Old 06-22-2008, 08:09 PM   eBay Motors   #9 (permalink)
BigRedChevy
Post Slut
BigRedChevy's Avatar
Nope, just the LLY
KYLE
Old 06-22-2008, 08:11 PM   eBay Motors   #10 (permalink)
duramaxchris06
Originally Posted by BigRedChevy View Post
Nope, just the LLY
alright, thank ya
2008 emblems
B&W turnover ball
