EGR delete kit? - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 23 (permalink) Old 10-05-2010, 11:34 AM Thread Starter
ebaker2006's Avatar
Yea I've noticed it's not much more expensive than the other tuners I've been looking at anyways.
BTW Sweet truck!!!!
ebaker2006 is offline
post #12 of 23 (permalink) Old 10-06-2010, 05:02 PM
audiomixer's Avatar
Usually when you get EFI live, the seller will give you a tune or 2 of your choice. Can't go wrong. Great vendors on this site that will help you. Its your option at that point on leaving that crap on or removing it. Removing it involves more than just a simple disable of the EGR function under Engine Calibration. It also requires a disabling of the DTC MIL and Test Enablers that deal with EGR function. The ECM wants to "see" the solenoids and all that junk and will throw codes if you remove them and have not disabled its functions within the Engine Diagnostics section of EFI live. Also there is one sensor (2nd baro sensor) just behind the fuel filter that you do not want to remove in any case or you will throw the P2227 (baro sensor performance code) and your engine will be gutless (been there, done that ). The ECM insists on "seeing" the sensor electrically and if it does, its happy. The rest you can remove if you want with EFI live.
Chevrolet '16 2500HD 4WD LTZ CC D/A LML Deep Ocean Blue, stock.
GMC '04 2500HD SLE CC D/A LB7 SB Summit White, LineX, Nicktane, JK headlight harness, JK fuel pump and harness, Banks exhaust, EFI Live, intake horn mod, Suncoast 6 speed conversion, injectors at 112,265 (#8 again at 136K), ...and all 8 again at 168,368.
VW '01 Bug TDI 6 spd ERF manual, 11mm IP, DLC 520 injectors, Malone stage 2 tuning. My FUN summer driver.
Fuel mileage? Who cares, its a diesel.
audiomixer is offline
post #13 of 23 (permalink) Old 10-07-2010, 07:39 AM Thread Starter
ebaker2006's Avatar
So what your basically saying is dont hassle with physically removing it and let efi live do the work?
post #14 of 23 (permalink) Old 10-07-2010, 08:33 PM
audiomixer's Avatar
Pretty much unless you are going to run a big tune with lots of boost and exceed 25PSI.
post #15 of 23 (permalink) Old 10-08-2010, 06:40 AM Thread Starter
ebaker2006's Avatar
Thanks for all the help and suggestions!
post #16 of 23 (permalink) Old 10-25-2010, 10:41 AM
I Sell Fireworks!
pyromax1012's Avatar
Just curious, why would you want to remove the EGR if you were to exceed 25 lbs of boost? I found out over the weekend my truck is CA Emissions w. EGR so I'm just wondering if I do the EGR delete via EFI Live what are the consequences of running the truck over 25 psi of boost with the EGR valve/cooler still on the truck?
I just looked at some pics of a guys intake and valves after 30K mi with the EGR on and not blocked, wow those were nasty! I can't even imagine what mine looks like.
2011 Chevrolet Silverado LT 4X4 ECSB
Still has that new car smell...
2003 GMC Sierra 2500 H/D LB7 (SOLD)
181K, AT, AMSOIL OIL AND AIR FILTER
pyromax1012 is offline
post #17 of 23 (permalink) Old 10-25-2010, 10:46 AM
Meyer Performance
lutzjk913's Avatar
^^^^^high boost levels will push valve open
Joe
Mine: 2008 CCLB Duramax 13.68 @ 98.25
Hers: 2016 Explorer Sport twin turboed V6
The life of my truck
Pics of my truck
lutzjk913 is online now
post #18 of 23 (permalink) Old 10-25-2010, 11:43 AM
Its just a worktruck
DMAXchris's Avatar
Like said above, it will push it open. A simple EGR blocker plate will fix this. I've had mine blocked for well over 2 years. I see about 35 psi on my race tune. I think I'm ready to delete the whole system. It has been proven to be a 30+ rwhp gain and my blocker plate is starting to leak.
BTW Sweet truck!!!!
Thanks!!! Its lots of fun and still gets the jobs done during the week!!
06 LBZ EC/LB 4x4
Built Motor/Trans Bullseye s475/87/.9 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76 @ 115
DMAXchris is offline
post #19 of 23 (permalink) Old 10-25-2010, 12:12 PM
NewEST Spinny Thinggg
seth999's Avatar
yeah I bit the bullet and just took of all egr parts n bought a full delete kit its deffinatly the way to go...theres so much more room in there now
06' CHEVY 2500HD CCSB PULLER/DD
Danville Billet S475
SoCal Stg.2 Heads
SoCal Cam
Mahle Forged Pistons .040 ovr
Hamilton Rods
Floor it pump
Dipper sticks
ATS Trans/CoPilot/TC
Other Stuff...
seth999 is offline
post #20 of 23 (permalink) Old 10-27-2010, 08:40 AM Thread Starter
ebaker2006's Avatar
where did you get the full delete kit from??
2003 Chevy Silverado straight pipe
17" Weld Racing Renegade XT
35x12.50 Nitto Trail Grapplers
