So thanks to Monstermax' advise I now have a working fuel guage again!!! And yes the easiest way to get to the fuel tank is to take the bed off (thats if your goose neck ball is'nt rusted on to the bed!!!). The only thing i did different was, I used a dremal tool to flatten out the plastic pieces on the sender body, I also used a 24GA piece of metal, real thin but strong enough. I had one question though.... what do I do with the other wires/harness that the Dorman 911-005 comes with? and once again Monstermax came to the rescue!! just use the old harness by taking out the blue wires from the old harness with a small screw driver or pick and replace with the purple wires on the new sensor (so no splicing and saves some time!!). Im not sure if it was the size of metal that i used, but i didnt have any problems putting the unit in with the float already attached. The only thing i did wrong was mounted the new sensor the "wrong" way... it still reads right but had to bend the float to make it work (atleast ill know when im getting low on fuel, but will be marking full for a while after filling up) so make sure to mount the sweeper board the same way the old one was. All in all it works great!!! and the best part saved a ton of money!!!!! Im not sure on how to post pics, so if I can get some help on that ill put a couple of what I did.
Andrew
2002 lb7 CC/SB 2500HD
