solar panel instead of outlet for block heater? - Chevy and GMC Duramax Diesel Forum
post #1 of 21 (permalink) Old 10-26-2010, 09:10 PM Thread Starter
has anyone ever heard of using a solar panel for a block heater? I am living in a place that has nowhere to plug into, its gettin close to winter and I would really like to get something to keep it warm overnight.
'03 lb7 ec dsp5 and tunes by merchant automotive in zeeland, mi, built trans by merchant as well(all but billet input and output),s&b intake, 5 inch mbrp turbo back with muffler delete 250,000 miles
yamaboy429 is offline
post #2 of 21 (permalink) Old 10-26-2010, 10:36 PM
adas's Avatar
so you want to use a solar panel (that gets energy from the sun, during the day)
to keep the block warm, through the night(When its dark, and only mooonlight)?
hmm....
Adam-941 FL
11' LML Denali CC/SB 4wd
PPEI Max Effort|AirDog II|5" FloPro|Wherli Fab Goodies
22x11 Fuel Kranks|Toyo MT 33/12.5/22|Cool stuff
Lots of goodies on the way
05 RC/LB LLY 2wd Play truck
Twinned S475/Stock|Suncoast GMaxIV|ATP Tunes|AirDog 150 w/Billet Sump|LBZ goodies|SoFlo Dual 6 stacks
Lowered|No Overloads|Custom Trac Bars|305/50/20 420s w/ 20x10 Menace
adas is offline
post #3 of 21 (permalink) Old 10-26-2010, 10:57 PM
xposr2vicious's Avatar
hahaha well said adas.. well said... obviously some ppl are technically challenged
Steven
2002 Chevy 2500HD LB7 Duramax <Has 101k, PPE HOT+2 on 225 tune, Edge CTS, Industrial Injection 42% cp3, AIRDOG 165, Banks Ram Air, Banks Wastegate Actuator, MBRP Single 5" Offroad Exhaust with 6" Tip, 7" CST Lift, PPE Deep Sump Pan, PPE Diff Cover, 06' Mirrors & Taillights, Pioneer Deck & Sound, Rancho Shox :rockin >
xposr2vicious is offline
post #4 of 21 (permalink) Old 10-26-2010, 11:08 PM
Maybe look into a diesel fired Wabasso or Espar heaters.
I have worked on engines all my life, spent 19 years at FreightlinnerI live in the Kootenay region of B.C. I have a 2007 NBS White 3500 GMC SLE Duramax Alison 17 inch aluminum SRW Crew-cab long-box White linex in the box and black in the wheel wells BW turn-over ball. all stock.
Johnp33 is offline
post #5 of 21 (permalink) Old 10-26-2010, 11:40 PM Thread Starter
im not challenged you jack wagon lol...maybe but im talking about using solar power to charge some kind of a battery or something to warm the block over night... I have absolutely no way to plug it in
post #6 of 21 (permalink) Old 10-27-2010, 01:06 AM
I would look into a diesel fired heater if you have no way to plug your truck in and want to. They are like a small boile circulates the engine coolant through them
to heat the motor. You can get them with time delays so it will turn on a few hours before you need to use the truck or whenever you want it to
2003 GMC 2500 Big dipper trans, dual cp3, s366, EFIlive, trac bars, steering braces, lockers
1998 Dodge 2500 24v cummins BHAF 4" exhaust 6" stacks edge juice with attitude 6" procomp lift
1995 Doge 2500 12v Pump work hood stack
justinwilliamskx is offline
post #7 of 21 (permalink) Old 10-27-2010, 03:14 AM
Vanned this place
TheStepChild's Avatar
. Vans had those as an option for faster warmups. I know the aftermarket ones can pre-warm up the engine. But really just wanted to ho the place up with van info
Originally Posted by Jeremy Clarkson View Post
Some say he was conceived in a cargo van
TheStepChild is offline
post #8 of 21 (permalink) Old 10-27-2010, 10:48 AM Thread Starter
aright, i like the sound of the diesel powered heater.. i think it would work perfect, but where would i start looking for one, and what would the price be? I was looking around and i could only find ones for semi's.
post #9 of 21 (permalink) Old 10-27-2010, 05:21 PM
I would Google Webasto, and look for a local dealer and ask or the yellow pages.
Johnp33 is offline
post #10 of 21 (permalink) Old 10-27-2010, 07:40 PM Thread Starter
i couldnt find any for less than about a grand. I dont have near that much to spend on something like that
