COOLANT LEAK. help needed!!! - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 10-31-2010, 02:01 PM Thread Starter
Cool COOLANT LEAK. help needed!!!
I have a 2001 Duramax thats leaking coolant somewhere on front of the drivers side part of the engine..there seems to be no signs that the water pump is bad..where else could it be coming from??
2001 Ext cab Duramax.
PPE HOT+2 ET,PPE Boost valve, AFE Intake, FASS 150,mbrp 5" exhaust,PPE tie rod sleeves.Going on 280,000 miles and wantin' more! :rockin
2004 Dodge cummins 6speed.
Edge juice W/ hot unlock + smarty+ Fass 150+ Super B+ heavy foot= BLOWN UP:booboo
1997 5spd 12 Valve. 13mm pump, 370 marine injectors, Super B ( wants more). A true Brute.
Badapple is offline
post #2 of 9 (permalink) Old 10-31-2010, 02:54 PM
ATPTRUCKS
sickdiesel's Avatar
is it leaking between the head and block? could be a blown head gasket
Blackout :06 GMC lbz 4x4 Built motor, HSP twins, DDP Injectors, Self built trans 11.68@118.5
Over Built :07 Chevy lbz 4x4 Caged and built 10.42@134
The Car: 2014 Chevy Cruze 2.0 Diesel
Special thanks to: Mike L, Gtrippin, IdahoRob, Dmaxstore, HSP, ISSPRO, Yukon, Airdog
LIKE US ON FACEBOOK!
Adrenaline Truck Performance IDAHO ROB 208.685.1000
sickdiesel is offline
post #3 of 9 (permalink) Old 10-31-2010, 05:18 PM
Administrator
ob_1jr's Avatar
take a real close look at the waterpump.... Sometimes they dont leak very much. I have been through a few waterpumps.
2016 GMC Sierra 2500HD Denali
Extang Blackmax Tonneau
X-pel clear bra
SOLD 2004 GMC Sierra LB7
ob_1jr is offline
post #4 of 9 (permalink) Old 10-31-2010, 05:52 PM
Durallymax's Avatar
Water pump .the tubes running to the water pump. Hgs, the turbo coolant return line. If you can't find it get some tracer dye and a uv least light.
Durallymax is offline
post #5 of 9 (permalink) Old 10-31-2010, 06:30 PM
turbo return line, or the pipe running from the crossover pipe to the return pipe just before the water pumpm dunno what its called....
2001 LB7 broken again. this time it's in the front yard.
BackYardDiesel is offline
post #6 of 9 (permalink) Old 10-31-2010, 07:11 PM
NADC 01 Duramax's Avatar
Thermostat housing
Take a look at your thermostat housing. I have a leak there from the aluminum warping. Also look at the down pipes from the housing where they go into the block.
2001 2500 HD BROKEN
1998 TDI Jetta
NADC 01 Duramax is offline
post #7 of 9 (permalink) Old 10-31-2010, 07:13 PM
waterpump man been there done that
nelsonlly is offline
post #8 of 9 (permalink) Old 10-31-2010, 07:33 PM
Killawatt's Avatar
Just did my water pump. It's not too bad
2004.5 Chevy 2500HD LLY Crew Cab 4wd/ Banks Six Gun w/ speed loader,banks IQ banks ram air and 4" exhaust no cat, Ready lift torsion keys. 250k miles and counting
Killawatt is offline
post #9 of 9 (permalink) Old 11-01-2010, 10:29 AM
XBoxLive: RenegadeDuramax
XtremeDMax's Avatar
Send a message via Yahoo to XtremeDMax
It's probably coming from the weep-hole on the bottom of the water pump housing. Time for a new one. They aren't too bad.
2015 Silverado 2500HD CCSB LTZ Dmax
Originally Posted by TheStepChild View Post
You want your exhaust to be like a fart. You can't see it but you know the effects of it.
If you can see your fart you got problems. If you can see your exhaust ...
XtremeDMax is offline
