Loss of power - Chevy and GMC Duramax Diesel Forum
post #1 of 15 (permalink) Old 11-08-2010, 05:21 PM Thread Starter
01LB7DRWCC4x4's Avatar
Loss of power
I was pulling a 40ft 5th wheel up a hill and the truck lost all power until it dropped to below 40 then all the power came back. Then on thursday my mom was pulling a hill with just a 3 horse trailer up a hill and she said it did the same thing. Any ideas I havent pulled after and I need to use it again soon. The programmer is on tow preformance mode.
01 Chevy Silverado Crew Cab 3500 Dually 4X4 LB7
Mods: Straight Pipe, K&N Filter, Bully Dog Pyro and Boost Gauges, Air Box Mod, Intake Horn Mod, SuperChips Cortex Tuner, Jvc Deck, Pionner amp, MTX subs.
89 Chevy Camaro RS Convertible 305 auto, working on engine mods
76 Chevy K-10 on 38's
87 Toyota 4Runner stock with custom bumpers and 30's
82 Yamaha XJ-750 4 Cylinder motorcycle all original
94 Gulfstream Tourmaster 5th wheel 38' long 2 slide (my home) got it free :rockin
01LB7DRWCC4x4 is offline
post #2 of 15 (permalink) Old 11-08-2010, 05:22 PM
BUBBA3M's Avatar
It may be starving for fuel at that speed. When was the last time you changed your fuel filter?
2013 LML, 6 spd Ally, CC/SB, Bone Stock
2015 Copper Canyon 33ft 5th wheel
BUBBA3M is offline
post #3 of 15 (permalink) Old 11-08-2010, 05:25 PM Thread Starter
I changed it about 3,000 miles ago.
post #4 of 15 (permalink) Old 11-08-2010, 05:35 PM
BUBBA3M's Avatar
You may have gotten some bad fuel, I would start with replacing it again.
BUBBA3M is offline
post #5 of 15 (permalink) Old 11-08-2010, 05:40 PM Thread Starter
Ill have to do that. When it comes to filters do I need to go to gm for an ac delco or is there an aftermarket one that works as well or better.
post #6 of 15 (permalink) Old 11-08-2010, 05:50 PM
It could also be the FPRV. Once you back off on the pedal it resets after a few seconds and down the road you go, ... until the next time.
I was ridin' in a DMax that would do this about every 40 to 50 miles, when towing. Then, we figured out it was happening most often when going uphill. I think the owner fixed it by shimming the Fuel Pressure Relief Valve.
'09 2500 Z-71 HD, Wyoming Edition
'06 Desert Fox TH
'53 Cranky Ex-Spouse
N8AGS
Len Todd is offline
post #7 of 15 (permalink) Old 11-09-2010, 09:47 AM Thread Starter
Ok Im new to the dmax where is the FPRV at and wouldnt it through a code or something? It only started doing this since I got the programer.
post #8 of 15 (permalink) Old 11-09-2010, 10:37 AM
XBoxLive: RenegadeDuramax
XtremeDMax's Avatar
Send a message via Yahoo to XtremeDMax
FPRV is a b*tch to change... gotta dig to it. It would usually throw a code, P0089 (almost positive that's the right code).
If it only started doing it when you used the tuner, try flashing it back to stock and see if it still does it. If that fixes it, try to flash it back to tow. If the problem persists, go back to stock and return your tuner.
It could have bad programming or it could be that it doesn't mesh well with your ECM/TCM.
2015 Silverado 2500HD CCSB LTZ Dmax
Originally Posted by TheStepChild View Post
You want your exhaust to be like a fart. You can't see it but you know the effects of it.
If you can see your fart you got problems. If you can see your exhaust ...
XtremeDMax is offline
post #9 of 15 (permalink) Old 11-09-2010, 10:41 AM Thread Starter
Ill try that. Its not throughing a code so I wasnt sure that it could be the FPRV.
post #10 of 15 (permalink) Old 11-09-2010, 10:45 AM
XtremeDMax's Avatar
It could still be the FPR but USUALLY it throws a code...
Any problems with loss of power usually results from a loss of fuel or air, or a combo of the two... that's really all these trucks need.
Speaking of air... is the air filter clean? Any signs of turbo leaks?
