oil pump - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 11-21-2010, 07:44 PM Thread Starter
duramaxbd03's Avatar
Send a message via AIM to duramaxbd03
oil pump
has anyone changed one? how hard is it?
2007.5 Silverado 2500HD 4X4 Reg Cab LB, LMM, RED
Edge Cts, 4inch exhaust, Efi Live
2005 Silverado 2500HD 4x4, Reg Cab LB, LLY, RED
285/50/20 Nitto 420s, 20x10 Gear Alloy 726MB
Edge Insight, Autometer gauges, 3inch Drop Shackles
3inch boost tubes, Raptor Liftpump, 3inch Profab Ybridge, Arp Headstuds
Billet HTT S366, 45% Injectors, 85% Cp3, Hamilton Valve Springs
LML Manifold, 4" Exhaust,7inch Stack, 60" Traction Bars
Blackout Performance Trans with 1058
Tuned and Built by Blackout Performance
630rwhp 1150rwtq 11.8@111 -Jake
duramaxbd03 is offline
post #2 of 10 (permalink) Old 11-21-2010, 07:49 PM
duratothemax's Avatar
engine has to come out.
ben
06 audi S4, V8/6spd
05 dmax/allison...always testing something new
-BT DieselWorks, LLC-
[SIZE="3"]Specializing in a wide range of custom electronics and great gadgets for your 2001+ GM full size truck/SUV
Allison torque converter lockup controllers, Allison Tap-Shift kits, digital DSP-5 switches, affordable injector harness repair kits, and much more!
duratothemax is offline
post #3 of 10 (permalink) Old 11-21-2010, 07:51 PM
DuramaxForum Guru
kman2468's Avatar
Send a message via AIM to kman2468
doesnt pan have to be dropped?
Kyle
13 lml stock
sold 04.5 lly
kman2468 is offline
post #4 of 10 (permalink) Old 11-21-2010, 07:54 PM
Yes, the upper pan has to come off. To get the upper pan off the engine has to come out.
BUT If you are hell-bent on doing it in the truck, the trans has to come out, the entire front suspension and front differential has to come out. Along with the whole front of the engine. Much easier to just pull the engine in my opinion.
I have to ask though...what makes you say the oil pump needs to be replaced? Oil pump failures are incredibly rare..
06 audi S4, V8/6spd
post #5 of 10 (permalink) Old 11-21-2010, 08:21 PM Thread Starter
i dont believe its out... its just my gauge is doin all kinds of funny things... to were it will be reading fine then drop to 0 and start dinging then... start working again or sometimes staying at 0
post #6 of 10 (permalink) Old 11-21-2010, 08:27 PM
gr8shot's Avatar
Probably the sender. Much more common failure, or the cluster itself.
Jesse
2004 LB7
Tastefully modded
Lots of miles
Built by Husker Diesel
gr8shot is offline
post #7 of 10 (permalink) Old 11-21-2010, 08:33 PM
I agree. 99 times out of 100 its the sender.
The duramax oil pumps are very simple and reliable. I have only heard of ONE oil pump failure.
06 audi S4, V8/6spd
post #8 of 10 (permalink) Old 11-21-2010, 08:43 PM Thread Starter
i have a new sender sitting here waiting to be put in lol.... so i heard they suck to do
post #9 of 10 (permalink) Old 11-21-2010, 09:27 PM
If the stepper motor is bad it wont set the oil warning light on.
'06 Chevrolet CC/SB LT3 LBZ 4x4
MBRP 4" Straight, BFG KO's, Autometer Ultralites, HID's, B&W Turnover Ball,
Rhino Liner, Predator on 40hp with more to come.
'08 Chevrolet CC/LB LMM Work Truck 4x4
Deleted, DPF-R, Reading Utility Bed, Leveled on 285's, Rhino Lined
LBZ_Duramax is offline
post #10 of 10 (permalink) Old 11-23-2010, 01:01 AM
Tow Master's Avatar
His would be the other 1
I guarentee you they are easiar to do then the oil pump. You sure there isnt fuel in the oil from the bad injector?
Jason
Tow Master is offline
