100hp injectors poor fuel mileage - Chevy and GMC Duramax Diesel Forum
post #1 of 21 (permalink) Old 11-29-2010, 07:22 PM Thread Starter
LB7, I just replaced all stock injectors at 130,000 miles because of fuel in crankcase. I replaced with Scheid Diesel Lightning 100 hp injectors, and installed a FASS lift pump with filters. Runs great, has more power, doesn't smoke much.
I just pulled a trailer 500 miles empty at 74-79 mph and got 11-12 miles to gallon. Returned loaded with a Kubota RTV running 74-79 mph and got 10-11 miles to gallon.
When I push the speed to 79 mph (2400 RPM) empty or loaded the "service engine soon" light would come on. I am not sure what the code is, or how to get it.
Why is fuel mileage so bad? How can I get back to stock fuel economy of 15 mpg.
02 Silverado 2500HD Crew Cab 4X4, 132000 miles,
Scheid Diesel Lightning 100 HP injectors, FASS lift pump & filter
Last edited by Randy Gough; 11-29-2010 at 07:25 PM. Reason: Did not list engine lb7
Randy Gough is offline
post #2 of 21 (permalink) Old 11-29-2010, 07:26 PM
GeneralTJI's Avatar
Is the truck tuned? with EFI live or HP Tuners? (a programmer is not tuning, and won't compensate for larger injectors properly).
Larger injectors require custom tuning if you really want them right....
06 LBZ / 6spd Allison 4x4 ec/sb
Self built/tuned sideways s366 setup | DPC converter / Co-Pilot | 1792 / BD Filter| Black 5" Hood Stack | Homebuilt Trac Bars | Coil-overs | 250psi water/meth | Black MM951's | roll pan | Autometer/ISSpro/UltraGauge | sleeves | self Lowered | deep pan etc.
12.61 @ 105 - 5800ft elev (stock trans) 12.6 vid
Parted out my car for a Pilot's License!!!
GravityKnightFlying
GeneralTJI is offline
post #3 of 21 (permalink) Old 11-29-2010, 07:28 PM
diesel vein's Avatar
What was the mileage before??it does sound unusually low but I've heard injectors will do it.
04 LB7,BUILT TRANS,LBZ RODS
STUDDED,DELIPPED,KEYED
BRACED,KENNEDY PUMPS
LBZ FPR,ALLI LOCKER
TRAC BARS;PUMP RUB
alot of small stuff.
the name's jason ....
diesel vein is offline
post #4 of 21 (permalink) Old 11-29-2010, 07:32 PM Thread Starter
No tuners or programmers, bone stock.
So I need to have it tuned? How? Where?
post #5 of 21 (permalink) Old 11-29-2010, 07:33 PM
Banned
well going 80mph certainly ISN'T helping your MPG's.
Slow down to 65-70.
Hondarider552 is offline
post #6 of 21 (permalink) Old 11-29-2010, 07:36 PM
can you check your codes somehow im thinking it is a 1093
02 ccsb performancetruckproducts.com
addelo6 is offline
post #7 of 21 (permalink) Old 11-29-2010, 07:38 PM Thread Starter
What is a 1093 code? Is it a fuel pressure/supply issue?
post #8 of 21 (permalink) Old 11-29-2010, 07:40 PM Thread Starter
How can I check the code?
post #9 of 21 (permalink) Old 11-29-2010, 07:41 PM
GeneralTJI's Avatar
Ok... heres basically whats happening.
Your injectors open and close for a period of time when they spray- (Pulsewidth). Obviously when they are opened longer you get more fuel (heavier throttle and rpm)... of course fuel pressure plays a part in how much fuel is injected as well.
With larger injectors, you are getting more fuel injected per injection event. It will probably effect you the worst under cruise, light throttle etc. I would imagine the throttle is a little more touchy depending on how much the MAF is limiting fueling.
With custom tuning you can adjust injector pulsewidth to compensate for the larger injectors, you can also adjust injection timing, fuel pressure etc. to dial in everything.
You should get the CEL pulled.... most auto parts stores will scan for codes for free.
EDIT: Anyone know how these "100hp" injectors would stack up against a % over injector?
GravityKnightFlying
post #10 of 21 (permalink) Old 11-29-2010, 07:41 PM
low rail pressure during power enrichment
addelo6 is offline
