Old 07-20-2008, 09:22 AM   eBay Motors   #21 (permalink)
deereboy80
Points: 286, Level: 5
Points: 286, Level: 5 Points: 286, Level: 5 Points: 286, Level: 5
Activity: 12%
Activity: 12% Activity: 12% Activity: 12%
deereboy80's Avatar
The egts never went above 1100-1150 when I did the same hills with my old powerstroke.
'04 GMC LB7 Crewcab Shortbed
AFE Stage 2 Intake
Diamond Eye 4" Single Exhaust
Edge Juice w/Attitude
Air Lift 5,000Lb bags with Ride Control
B&W Turnover Ball
deereboy80 is offline   Reply With Quote
Old 07-20-2008, 10:56 AM   eBay Motors   #22 (permalink)
BigRedChevy
Duramax Forum Moderator
Points: 6,761, Level: 35
Points: 6,761, Level: 35 Points: 6,761, Level: 35 Points: 6,761, Level: 35
Activity: 100%
BigRedChevy's Avatar
Yes the edge watches egts, but when you lug these things the egts will go up considerablly. You may not have a problem with them, i was just saying that they will be higher when you lugging than they will if you let it downshift and get a few rpms.
KYLE
05 Chevy LLY Crew Cab LT Dually 4x4, Crank it up Diesel Tie rod sleeves and centerlink, BD Diesel Remote Fuel Filter, EGR Blocked, TTS Dual Lift Pumps, FPRV Shim, Bullydog Outlook Monitor, AFE Stage 2 CAI, BD Diesel Manifold, Diamond Eye Turbo Direct Pipe, Diamond Eye 5" exhaust straight piped, Level Kit, Suncoast Stage IV w/ 1056 Torque Converter and Allison Deep pan
Old 08-02-2008, 06:58 PM   eBay Motors   #23 (permalink)
deereboy80
Activity: 12%
deereboy80's Avatar
Originally Posted by delong_1 View Post
a shop that one of my friends works at suggested that i buy the bd, so i looked into it it was only rated for 450 hp and was about the same price you mentioned, for less money you could get a trans that would hold over 600 hp or something comparable for a ton less. thats why i went with ats
Just curious where you got your specs at. I was talking to my shop the other day and I mentioned to him what you said. He said he's curious to where you saw your specs at because BD never will give him specs on it.
AFE Stage 2 Intake
B&W Turnover Ball
Old 08-02-2008, 07:02 PM   eBay Motors   #24 (permalink)
deereboy80
Activity: 12%
deereboy80's Avatar
My friend at this shop said he has two boys pulling sleds with this trans setup in it and they have never torn it up yet. They're both making over 500hp. BD does not offer different levels like suncoast does, hence when you buy one, your buying the equivalent of a stage 5 suncoast. He said the trans runs about 4400, the converter about 1800, and he gets 450 to install.
AFE Stage 2 Intake
B&W Turnover Ball
Old 08-04-2008, 08:03 AM   eBay Motors   #25 (permalink)
IdahoRob
Points: 3,774, Level: 25
Points: 3,774, Level: 25 Points: 3,774, Level: 25 Points: 3,774, Level: 25
Activity: 8%
Activity: 8% Activity: 8% Activity: 8%
IdahoRob's Avatar
If you call BD, they will tell you about the HP rating and warrenty.
2007 LBZ CCSB 4x4,EFI(tuned by me), ATP Transmission
11.89 on #2 http://s173.photobucket.com/albums/w...Coddens3mb.flv
PPE, EFI Live, Suncoast Dealer
Adrenaline Truck Performance 208.484.3670
IdahoRob is offline   Reply With Quote
Old 08-04-2008, 09:16 AM   eBay Motors   #26 (permalink)
aggar
Points: 2,586, Level: 21
Points: 2,586, Level: 21 Points: 2,586, Level: 21 Points: 2,586, Level: 21
Activity: 28%
Activity: 28% Activity: 28% Activity: 28%
aggar's Avatar
Wow that's kinda high. My SCIV with 1058 wasn't that much. I would stick with a Suncoast. I have about 15k on mine now with 500 hp since it was put in and it has not skipped a beat. Tows great and just shifts awesome. I'm getting upgraded to EFI live right now so we'll see how it does on the dirt draggin a big heavy steel box! My PPE does pretty good. I am highly sold on Suncoast. I have buddy who just got a SC put in his 07 Dodge and he's lovin it too. Goodluck with your decision.
2006 Crew Cab SB 4x4, Stock LBZ, Black with Gray leather, Factory Steps. Black H2's with 295/70/17 Nitto Terra Grapplers, Silverline 4" Turbo Back ss system w/Hushpower muffler. PPE Excelerator Hot + 2(set on 350), Bugshield, and grille insert. SCIV and 1058(Fleece Performance), HP 150 lift pump, Auto meter gauges and pod, EGR Blocker and FRPV shim kit,
Old 08-04-2008, 09:25 AM   eBay Motors   #27 (permalink)
gr8shot
Points: 1,817, Level: 17
Points: 1,817, Level: 17 Points: 1,817, Level: 17 Points: 1,817, Level: 17
Activity: 43%
Activity: 43% Activity: 43% Activity: 43%
gr8shot's Avatar
One thing you can do to help your hill climbing, is switch on the tow haul mode. That should help it hold gears a little longer, and keep it in OD longer.
Old 08-06-2008, 06:58 AM   eBay Motors   #28 (permalink)
bigdaddydiesel
BigDaddyDiesel
Points: 1,102, Level: 13
Points: 1,102, Level: 13 Points: 1,102, Level: 13 Points: 1,102, Level: 13
Activity: 79%
Activity: 79% Activity: 79% Activity: 79%
bigdaddydiesel's Avatar
I cannot speak to auto trannys at all, but I have a manual 6-spd, and in 6th going up long grades even pulling a loaded trailer my EGT's do go up, but not enough to cause problems, with the heaviest of loads, running 70-75 uphill they never go above 1350...
Just food for thought...
'03 LB7, K&N Intk AFE Fltr, 4in exhaust, Banks Six-gun w/ power PDA and Speed Loader, FASS Fuel System, 6-Spd Manual Tranny w/ Custom Ceramic Dual Disk Clutch By: South Bend, Pyro and Boost Gauges in the A-Pillar, 5000lb air bags on the rear, B&W Gooseneck hitch, and fifth wheel.
Old 08-06-2008, 01:50 PM   eBay Motors   #29 (permalink)
deereboy80
Activity: 12%
deereboy80's Avatar
All my towing is done with tow/haul mode on. I pull a 9,000 lb trailer daily. Occasionally I pull a 22.000 lb gooseneck averaging 28,000 lbs. gross. However, I am not trying to base my towing on those loads. If I can get my 9,000 lb trailer to pull nice, I will be happy.
AFE Stage 2 Intake
B&W Turnover Ball
Old 08-06-2008, 01:53 PM   eBay Motors   #30 (permalink)
deereboy80
Activity: 12%
deereboy80's Avatar
I would like to put a 6spd manual in this truck, but so far no one seems to think that this would be a good idea. Everyone says spring for an upgraded auto.
Just another question for bigdaddydiesel, Are your airbags helper bags, or are they full airride suspension?
AFE Stage 2 Intake
B&W Turnover Ball
