Well from what I researched/read,the 04.5-up can hold 650hp without hurting bottom end.Well yeah I forgot I have a 2001 so im probably gonna be holding at max what amount?Well alright how about,how much will it take to get my truck into the 11's?
Lots of trucks will make 650hp for awhile. In a 2wd you will need at least 700hp to run 11's, probably closer to 800hp. I would do a tranny a small turbo upgrade and some good tuning and your 2wd may get into the 12's. that is about as far as you can go safely with no internal work.
Mine came off the dyno the other day and did 540RWhp and 1090rwtq. My issue now is that im running out of fuel. There is only so much a stock CP3 and no lift pump can do
__________________ 2003 GMC Sierra LB7 ATS *EXTREME* Transmission, ATS Billet Flexplate, ATS Aurora 5000, 4" downpipe to a 5" Single Stack, ATS Epower Programmer, Custom 4" Intake with AFE Filter, ATS Billet Tie Rod Sleeves, FASS 150/150 www.atsdiesel.com 866-230-4092
$$$$$$$$$$$$$$ and lots of it...drop back into the 500's on HP and your Duramax will last alot longer..
i wouldn't look at anything else but EFILive if you want big HP but if you want a streetable t6ruck that will last a long time go with the ATS E-Power or PPE Hot ET+2..
__________________ James
TyreBoyz Pulling Team
Once you upgrade one thing, you have to do another, and once you get so high in HP and upgrades, then things start breaking, etc, etc. So unless you have a endless money pit, good luck.
__________________ RIDE: 2007 Chevy CC LBZ / 6 speed LIFT: Ready Lift Leveling Kit STARTER: VIPER 2 Way w/Turbo Timer SOUND: Pioneer P4000DVD - 6 1/2 Polk Audio everywhere else. ADD ONS: H1 Halo Projector headlights, Backup Camera, Dee Zee running boards, Chrome Grill, ExTang Solid Fold Tonneau Cover, Line of Fire w/reverse, custom bug shield/vent shades, TomTom GPS TIRES/WHEELS: 285/75-16 Firestone MT Tires on 16x8 ATX series Teflon Coated Wheels AIRFLOW: BANKS Monster Dual Exhaust, EGR blocked & CAT removed with MBRP replacment pipe and BANKS Ram Air. PROGRAMMERS: BANKS 6 Gun PDA w/Speed Loader --STACKED-- with Quadzilla Stealth 2
Not to be negative or anything it is gonna take a lot of that green stuff and time. But if you are serious about this good luck. Might want to add a few stages of nitrious.
__________________ 2002 Chevy LB7 Crew Cab
Ive been considering spraying my truck to try and jump into the 11's but i know the engine probally wont live but a few passes if any at all!! Dual fuelers and N20 = certian death!
