| Premium Membership | |
| | | 01-04.5 LB7 Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |  |
07-15-2008, 12:27 PM
eBay Motors
#1 (permalink)
| | Junior Member
| transfer case motor Does anyone know how difficult it is to remove the encoder motor from the ally? dealership says it took a dump. I dont want to pay 700 for a new one and perfer to do it myself. I have an 03 LB7 60k on it. |
| Advertisement
07-15-2008, 11:02 PM
eBay Motors
#2 (permalink)
| | Member
| if you are talking the motor that shifts the transfer case its on the out side if the tcase should be easy to change like 3 or 4 bolts and a wire plug and i do not think it will leak oil
__________________ 2002 CREWCAB DUELLY 4X4 6SP MANUAL WITH SUPERCHIPS,SBC single mass/disk flywheel,ppe boost valve, K&N , MUFFLER DELEATE OPP. AND CROME FLAME GRILL |
07-15-2008, 11:23 PM
eBay Motors
#3 (permalink)
| | Super Man Moderator Points: 10,639, Level: 44 |
| Ya i agree. I havent done one myself but I looked at mine before and I think its easy to do. Buy the new one and see what the side thats in the trans looks like. As long as there are no cables going to or from it Id say do it yourself!
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 4 Kicker 10in Subs & Punch 250amp in 2 custom boxs. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 285/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake |
07-15-2008, 11:35 PM
eBay Motors
#4 (permalink)
| | Member
| It Should Look Like A Power Window Motor But Just Has A Square Shank That Goes Into The Motor Gears To Turn A Shaft To Shift
07-15-2008, 11:45 PM
eBay Motors
#5 (permalink)
| Quote:
Originally Posted by CEB0217 It Should Look Like A Power Window Motor But Just Has A Square Shank That Goes Into The Motor Gears To Turn A Shaft To Shift |
Thats kinda what I thought! I wonder if there is a key way so that the trucks is not in 4Hi and the motor thinks its in 2hi?
07-16-2008, 09:17 AM
eBay Motors
#6 (permalink)
| | Super Moderator
| I checked it out on alldatadiy.com and it looks pretty easy to change...the hardest part looks to be removing the propeller shaft (that's what they call it)....other than that it looks pretty easy. The part number that it shows for my truck for the part is 88962312. That is for the 263 transfercase. It says it should take .6 hours to replace. gmpartsdirect.com has the motor for 436 plus shipping....I would try to see if that is the right part number from the dealer if they will give it to you though.
4" turbo back MBRP exhaust
AFE Magnum Force Stage 2 Proguard 7 intake Kennedy Diesel Merchant Automotive My Photos |
07-16-2008, 10:56 AM
eBay Motors
#7 (permalink)
| | DuramaxForum Veteran
| Do it yourself it should not be that hard. Screw the dealer.
__________________ John
EFI LIVE with McRat tune, DPS5, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Suncoast Stage IV built by me. NO TALKING JUST LINE IT UP |
07-17-2008, 11:26 PM
eBay Motors
#8 (permalink)
| | Member
| check the wrecking yards we sell them from the one i work at all the time
08-15-2008, 12:23 PM
eBay Motors
#9 (permalink)
| | Junior Member
| Thanks to everyone for your help its greatly aprreciated!!! Update I got my ECM reflashed and its the damndest thing, its working fine now that the ecm was re-flashed. no codes at all 4x4 Works great high and low, woops ass in the mud!!!!!  |
08-15-2008, 01:17 PM
eBay Motors
#10 (permalink)
| | Senior Member
| good to know, hope it stays that way
__________________ Tom's new truck: red 08 duramax lmm , LTZ, crewcab 3500 4x4, stock for now for towing racecar trailer #10000lb's , spray in liner, has black aftermarket ranchhand cowboy bumber with cowcatcher for that sinister look , matching back bumper, added a toolbox in bed , new lights on push bar   chip to come later remember old age isn't for sissies !! never hollar whooaa!! http://i335.photobucket.com/albums/m...1/P9150004.jpg |
| Advertisement
