| I never had the problem but i installed a kit sold by Merchant automotive (GMDieseltech.com) that will stop it from ever happening in both trucks. Its a simple fix to a bad 99 cent clip that GM uses that causes all the problems!
__________________ 05 Chevy 2500HD dark blue reg cab ZF-6 speed/W South Bend Clutch ,Power by EFI Live W/Dsp2 , PPE GT4094R, ATS CP3x2, Modified Volant intake, MBRP front pipe, 4" side pipe, Holley Blue lift pump, Isspro gauges,Cognito Braces, SD Centerlink, Caltracs, ATS Tie Rod Sleeves Best ET 12.53@ 109 mph 04.5 Chevy 2500HD, silverbirch, D/A, CC/SB , EFI live, SCIV w/ATS 5Star converter,McRat shim mod, Wicked Diesels modded FPR, Kennedy dual lift pump, Modified Volant intake, Cognito Braces,CUD tie rod Sleeves, EGR BLocker,Diamond eye Down pipe, 4" dual exhaust, Elocker, MA Tcase Fix, B&W GN Hitch Best ET 13.53 @ 101mph |
