Glow plug problem? - Chevy and GMC Duramax Diesel Forum
post #1 of 18 (permalink) Old 12-29-2010, 05:09 PM Thread Starter
Glow plug problem?
03 gmc 2500hd duramax lb7, my batteries were low so i charged them then i started truck 6hours later and the check engine light came on..checked it p0380.. and now when i start the truck no mater if its hot or cold the glow plug light comes on and it starts funny like it revs alittle idles at 850 for a few sec. then drops to 750 and is fine..
jcdmax is offline
post #2 of 18 (permalink) Old 12-30-2010, 04:48 AM Thread Starter
had it plugged in last night and the glow plugs still came on? never has before! this truck is a cali emmision so im guess from what ive read oline i have have bad glow plugs?
jcdmax is offline
post #3 of 18 (permalink) Old 12-30-2010, 06:34 AM
lb7smoke's Avatar
I would try installing new glow plugs theyre only 11$ a peice i believe, just to be safe
2015 Denali Duramax... Stock for now
lb7smoke is offline
post #4 of 18 (permalink) Old 12-30-2010, 07:33 AM
Diesel Addict
not a 911 problem..
Project, Rogue Budget(Workstock Puller)
2006 GMC 2500HD, Stock Motor, EFILive by me, Billet 63 VVT, Motorsport Stroker CP3, 20% Nzls, ProFab Manis n Uppipes, BD IC, Hot Pipe IC, ProFab Y-Bridge, lots of other goodies
TYREBOYZ_DEMAXIN is offline
post #5 of 18 (permalink) Old 12-30-2010, 10:48 AM Thread Starter
now the truck starts and runs fine???? im gonna do batteries 1st if not that i hear gm covers the glow plugs for 10yr 200k miles so if it needs glow plugs they will do them and gm will pay.
jcdmax is offline
post #6 of 18 (permalink) Old 12-31-2010, 10:06 AM
XBoxLive: RenegadeDuramax
XtremeDMax's Avatar
Send a message via Yahoo to XtremeDMax
I don't believe the glow plugs are covered under that warranty... I think you are thinking about the injector warranty and that was 7rs/200,000 miles and most trucks are past the 7 year mark now.
Since you said you had a battery problem first, I think that your batteries are not holding their charge well enough and the voltage drop is messing with your glow plug controller. I am guessing you probably still have original batteries. Replace them.
If your problem persists, replace the glow plugs. They are cheap and you can do them yourself.
2015 Silverado 2500HD CCSB LTZ Dmax
Originally Posted by TheStepChild View Post
You want your exhaust to be like a fart. You can't see it but you know the effects of it.
If you can see your fart you got problems. If you can see your exhaust ...
XtremeDMax is offline
post #7 of 18 (permalink) Old 12-31-2010, 06:28 PM Thread Starter
i read on this forum the glow plugs have a 200k 10yr warranty.
jcdmax is offline
post #8 of 18 (permalink) Old 12-31-2010, 06:59 PM
lb7smoke's Avatar
they are not i believe i called my local gm dealer and they said they wont even warranty my injectors to 200k or glow plugs? soo..
lb7smoke is offline
post #9 of 18 (permalink) Old 01-02-2011, 06:04 AM Thread Starter
huh they messin with you, cuz the injectors r 7year 200k and glow plugs 10yr 200k i confirmed with my dealer about the injectors cuz mine are giving me starting trouble but i was 6mo pass the 7yr. cuz my truck was built i guess in 2002.5.. as far as the glow plugs there is an 1-800# u can look up to call on this forum.. i was told the lb7 are covered for 10yr 200k. maybe theyre tryin to dick u around??
jcdmax is offline
post #10 of 18 (permalink) Old 01-02-2011, 10:42 AM
lb7smoke's Avatar
my truck was made in 07/01 and its classified a 01? but im gunna call gm directly and not try to go through the stealership , but thanks because i need new glow plugs in starts way to hard
lb7smoke is offline
