oil dump - Chevy and GMC Duramax Diesel Forum
Old 01-04-2011, 10:27 AM   eBay Motors  #1 (permalink)
ltzgolf's Avatar
oil dump
I need a little help and or advice, last thursday I was driving to the desert with the family and noticed a slight vibration at a stop light went about another 20 miles and pulled to get fuel, found about 2 -3 qts oil under the truck and the undercarriage covered, coulndnt find any thing from the top, turbo hose or heads, couldnt see the rear main of course, it should be at the shop today. Again any insight would be great
2002 2500HD, CREWCAB, 4W, 5" CATBACK, BANKS COLD AIR INTAKE, BIG HEAD WASTEGATE, FASS TITANIUM 95, MIKE L STG 3 WITH NEW TRQ CONV, EDGE CS, COGNITO UCA & TIERODS, BROWNING O/U 12 G,GERMAN SHORTHAIR POINTER, EFI FROM IDAHO ROB AND DALLAS New 2012 CCSB 2W LT no mods yet
http://www.atptrucks.com/
ltzgolf is offline   Reply With Quote
Old 01-04-2011, 10:31 AM   eBay Motors  #2 (permalink)
MRCapps's Avatar
Do you have a PVC reroute?
"I wont be wronged, I wont be insulted and I wont be laid a hand on. I dont do these things to other people and I require the same from them." - John Wayne
Mr. Duramud - 04.5 LLY 4X4 :rockin - 315/75R16 Kelly Safari TSRs on black MickeyThompsons, BDS 7 inch HC Lift, Fox 2.0s w/Reservoirs, BDS Steering Stabalizer, BDS 5 inch Leafs, AMP Research Power Steps, AFE Turbo MP, AFE Intercooler tubes 3 inches (both sides), ProFab EGR delete tube, PCV reroute, MBRP 5 Inch turbo back, Diamond Eye down pipe, EFI by Rob, Edge Insight CTS, Cognito Pitman Idler Arm Supports, Cognito Pivot Assembly, HD MaxAxle CV Axles, Kryptonite Tie Rods...more on the way!Husker Diesel - 402-502-6961Looking to trade my Allison for a ZF-6
MRCapps is offline   Reply With Quote
Old 01-04-2011, 10:37 AM   eBay Motors  #3 (permalink)
ltzgolf's Avatar
dont believe the lb7 has that could be wrong though
Old 01-04-2011, 10:39 AM   eBay Motors  #4 (permalink)
MRCapps's Avatar
.... not sure.
Bump for ya
Good luck getting it resolved and let us know what you find!
Old 01-04-2011, 12:39 PM   eBay Motors  #5 (permalink)
Administrator
ob_1jr's Avatar
Sorry 2 say but it sounds like injectors. How was your oil level? Did it smell of fuel?
SOLD
305/70-16 BFG T/A KOs on Eagle Alloys Series 187
Clifford remote start. High Idle, Bilstein 5100s, 1.5" lift blocks
CAT fuel filter w/ nicktane adapter
Magnum Force Stage 2 intake with AMSOIL filter
Racor 2 Micron pre-OEM with heater & water sep
Lightforce 140s from Madjackracing
http://WWW.ATPTRUCKS.COM/
Old 01-04-2011, 12:43 PM   eBay Motors  #6 (permalink)
TBone's Avatar
The dreaded injector curse.....
2008 CC SB 4X4 LTZ
6" ProComp lift
20" ProComp wheels
35" Xtreame A/T's
4" Iron Cross step bars
TBone is offline   Reply With Quote
Old 01-04-2011, 04:05 PM   eBay Motors  #7 (permalink)
ltzgolf's Avatar
thanks for the input guys just got the truck back to the house and started looking for the reason for the oil spray on the under carriage and side of the engine found that it was coming from the tube by the vacumn pump so i checked the oil level again and found it to be high. draine about 6 -7 gallons out. Just las april I replaced them bought them through Pensocola diesel. Wont do that again
Old 01-04-2011, 04:14 PM   eBay Motors  #8 (permalink)
MRCapps's Avatar
6-7 GALLONS? Am I missing something??? That is not a little high... what, did they forget they filled it and just kept adding oil?
Old 01-04-2011, 04:28 PM   eBay Motors  #9 (permalink)
born country
Dmaxryan10's Avatar
i've heard nothing but bad from pensacola.
SOLD SOLD SOLD
06 cc/sb lbz
4094vvt, stage 4 trans, air dog 165, 4" to 6" stack EFI LIVE by nick, rhino lined rockers, fronteir extreme front and rear bumpers, trac bars, 35's, and some other go fast parts.
Dmaxryan10 is offline   Reply With Quote
Old 01-04-2011, 04:34 PM   eBay Motors  #10 (permalink)
Administrator
ob_1jr's Avatar
Most of the time when LB7 injectors go bad they dump fuel in the crankcase. Someone didn't fill it up that much.
SOLD
