check engine light and transmission not shifting - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 01-07-2011, 10:29 PM Thread Starter
I was driving today and the check engine light came on and it wont shift past 2nd or 3rd gear (i can't remember which)
Is there a way I can check the check engine code without a scanner? On my jeep it's a series of key on and off which pop the codes up on the dash, is that possible with this truck? (01)
Would I be able to reset it by disconnecting the battery for a few min?
The shifting feels fine, but then it won't go to the next gear. Starting from a stop is normal, no hard shift to second, no delay going into drive or reverse. I'm really hoping its some computer issue, because I HAVE to drive 180 miles home sunday morning, any help would be greatly appreciated!!
2006 Chevy 3500 DRW LBZ
dirtymike is offline
post #2 of 7 (permalink) Old 01-08-2011, 07:47 AM
Administrator
jc1843's Avatar
There is no way to read the codes without a scanner. Some codes will clear if you disconnect the batteries for 15-20 minutes, but if the problem is still there, it will go "Limp" again.
Drive to an auto parts store and have them check the codes-- write them down before they are cleared. (Some places will only read codes-- not erase them, because of liability)
Might be time to purchase a code reader, then you would be able to read, and clear codes yourself.
jc1843 is offline
post #3 of 7 (permalink) Old 01-08-2011, 09:23 AM Thread Starter
well i bought a hypertech tuner that is supposed to be able to read and clear codes, but it can't read the vin and won't do anything.
post #4 of 7 (permalink) Old 01-08-2011, 09:29 AM
lugnut's Avatar
You probably can't read any codes because the unit many not be communicating with the transmission control module (TCM). You will likely discover a P0700 in the ECM, but the TCM will contain the transmission code. My guess is the TCM has a problem upshifting into one of the higher gears so it is inhibiting the shifts. The TCM will only allow what is knows is right, and will inhibit shifting to prevent damage. It sounds like it is time to pay some diagnostic fees to a trans shop or dealer. I would recommend finding someone who has experience with Allison, otherwise they might do some guessing.
2006 2500HD LBZ 4X4 CC/SB LT3, 265/75R16, Rhino Liner, PCV Reroute, Resonator Plugged, 35w 6K HID Low Beam & Fog Lights, LED Interior Lights, ISSPro Pyro, Boost, & Rail Pressure Gauges in A-Pillar, Cognito Idler/Pitman supports, more to come soon.
1996 K2500 Suburban 7.4L, 265/75R16, Brush Guard, Nerf Bars
lugnut is offline
post #5 of 7 (permalink) Old 01-08-2011, 04:54 PM
(JESUS)
MUDYZER's Avatar
mine did the same thing about 30minutes ago..i did manage to get my hypertech to communicate (after 4 tries) cleared all 4 codes and drove it a few miles down the road it worked fine...Was told that the hypertech tuners were JUNK! wish i had known that before i bought it. If something happens again i`m sending it back to hypertech and get my money back....scott
2006 ECSB 2500HD 4x4 LBZ 285-75-16 nittos..
Pro-Flo 4" strait piped to 5" tip.
S&B cold air intake...
ALLIGATOR Diesel Tranny Lines....
Cognito pitman/idler arm support kit...
PPE tie rod sleeves....
EFI LIVE....DSP5....Trans Go Jr....thanks Jason
((((( JESUS )))))
MUDYZER is offline
post #6 of 7 (permalink) Old 01-08-2011, 05:03 PM
does the dtc port have power? check the cigarette lighter, if no power replace the fuse (a blue 15a micro style) in the panel in the engine bay...
2005 LLY C+ SB-->for sale
2013 LML CC
additions to come soon....
djmercer1 is offline
post #7 of 7 (permalink) Old 01-23-2012, 07:35 PM
yes i have power to the cigarette lighter and have checked all the fuses
01 chevy 4x4 ,Leveled out ,Tinted windows, Air intake ,efi live ,MA 700 , straight pipe ,Fass ,125% injectors ,Danville charger in progress
tookin2themax is offline
