Old 07-24-2008, 06:45 AM   eBay Motors   #1 (permalink)
REDHOSS02
REDHOSS02's Avatar
All These Injector Problems
I Don't Know About Yall But I Think This Whole Injector "warranty" Is A Bunch Of Bull. Y Keep Putting The Same Injectors In So They Can Go Bad Again? I Have Changed Mine 3 Times And Am About To Go On The 4th. My Truck Has 240,000 Miles And Is Ready For Another 300,000 But I Can't Afford To Keep Replacing These Things. Anyways I Am Wondering Since I Am Out Of Warranty On This Deal. How Am I Gonna Go About Testing An Injector To See If Its Bad? Also How Do You Check The Glow Plugs!
2002 LB7 CREW CAB LONG BED 245,000 MILES
PPE XCELERATOR LEVEL-5
4" TURBO BACK W/ 6" TIP
K&N INTAKE W/ 2" RESONATOR PLUG
285/75-16'S ON BLACK POWDER COATED MICKEY THOMPSONS
BANKS BIG HEAD W/ PPE BOOST VALVE
TRANNY UPGRADE (HOPEFULLY BULLET PROOF)
(2) 10" KENWOOD SUBS DOWNFIRE WITH 900 WATT KENWOOD AMP, INFINITY 3-WAYS, PIONEER DECK W/ NAV-Y
REDHOSS02 is offline   Reply With Quote
Old 07-24-2008, 07:42 AM   eBay Motors   #2 (permalink)
DuramaxNoKaOi
What type of fuel filter do you use? Do you use an second fuel filter system? Do you use any additives for lubricity?
In my opinion you shouldn't have to do all these things after buying a 45 K truck just to get a normal lifespan out of injectors, however I think thats what we need to do. Look at major manufactures life CAT, they use great filters, 1 or 2 micron filters. I think GM just dropped the ball completely on the fuel filters on our truck and thats why the injectors fail so much. The dry low sulpher diesel isn't helping either. Bosch recommends anywhere from 3-5 micron filtration with 97% efficiency. I'm not exactly sure what most fuel filters micron rating is for our trucks, but I'm going to call a couple dealerships- or just drop by and get the PN of the filter that they sell, then I'll be getting ahold of the manufacturer to see what the filtration specs are- and maybe, just maybe we might have a case against GM for not fulfilling their part of the deal. So, in the mean time, I will use I'd use a 2 micron filter that goes on the factory location, I just found this site that has a major name brand 2 mic for cheap Shop and I'd also run a secondary filter system that can be had for anywhere from 100 to 700$ and lastly I'd run a lubricity additive with every tank. Here is a link for a study that was done in regards to lubricity- I just ordered the opti-lube XPD because it ranked so well in the test. Lubricity Additive Study Results - Diesel Place
Hope this helps, I know my truck is in the shop right now getting the injectors replaced and when it gets out I'll have the new 2 micron filter installed before it ever runs on the new injectors, and the day it gets out I'm putting on a remote filter, and using additive every tank to see if it was in fact GM's poor filter design- and because I simply cant afford 4500$ a pop.
DuramaxNoKaOi is offline   Reply With Quote
Old 07-24-2008, 09:51 AM   eBay Motors   #3 (permalink)
REDHOSS02
REDHOSS02's Avatar
Well I Wish You Luck And Maybe We Could Overturn This Deal. Please Let Me Know What You Come Up With. "pm" Me The Results. Thanks For The Info!!
Old 07-24-2008, 09:51 AM   eBay Motors   #4 (permalink)
REDHOSS02
REDHOSS02's Avatar
Still Need Info On How To Check The Injectors!! Thanks!!
Old 07-25-2008, 09:07 AM   eBay Motors   #5 (permalink)
DuramaxNoKaOi
What are you trying to check on the injectors?
Take your oil dipstick out and smell it, if you smell diesel your injectors are bad.
If you nail the gas and a whiteish blueish smoke comes out your injectors are probably bad.
Old 07-25-2008, 09:35 AM   eBay Motors   #6 (permalink)
Super D
Hello All! I'm new to this forum but GM is making me crazy. My truck is in the shop right now and they just called saying that my injectors are sticking but the return rate is fine so there NOT going to replace my injectors! Please help! I really don't want to pay for new injectors. They told me to get Pen Ray injector cleaner and try that they think something is holding them open any advice would be greatly appreciated!!
03 Chevy 2500hd LB7\LLY
Super D is offline   Reply With Quote
Old 07-25-2008, 02:43 PM   eBay Motors   #7 (permalink)
REDHOSS02
REDHOSS02's Avatar
What A Mess!
Yes There Is Diesel In The Crank Case And There Is A Lil Blue Smoke Not Like All The Times Before But There Is Some. Also A Coolant Leak But No Detection Of Leaks Anywhere. Problems? Yes! I Just Got Off The Phone With Gm And Terrorized Them To Try And Get My Way We'll See Where It Goes. Good Luck To Everyone Else With The Same Problems!!
Old 07-25-2008, 04:42 PM   eBay Motors   #8 (permalink)
DuramaxNoKaOi
Just be careful about terrorizing GM. When I took my truck in I took my resonator plug off and put it back to factory. I also tipped the service guy and mechanic that was going to work on my truck. Wait.... I just saw your truck is out of warranty... unless the injectors were replaced in the last year or 12,00 miles. If not, give em hell!!! If there is diesel in the oil I wouldn't drive the truck- the diesel is breaking down the oil. Good luck bud
Old 07-25-2008, 06:23 PM   eBay Motors   #9 (permalink)
fordassassin
fordassassin's Avatar
Well,I got 180k on my truck and they are replacing the injectors again.
Well the guy that works at the dealer is my buddy and he said the white smoke doesn't matter.He said that GM doesn't care about the white smoke.They just want it to fail the scanner test.If it fails the scanner test it can get new injectors.
I get my injectors after August 1st hopefully
01 RegularCab longbed 4x2 STOCK FOR NOW!!
04 Dodge 5.9 QC shortbed 4x4 12 second 1/4
02 Ford 7.3 QC shortbed 4x4 600+
fordassassin is offline   Reply With Quote
Old 07-25-2008, 09:04 PM   eBay Motors   #10 (permalink)
corjc
corjc's Avatar
they do a cylinder contribution test if it fails they replace injectors
2007 LMM
6 inch pro comp lift
dick cepek dc-1s
halo projector headlights
l.e.d tail lights
billet grill
billet bowtie
corjc is offline   Reply With Quote
