hard starting in cold weather - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 01-17-2011, 01:25 PM Thread Starter
Snoman's Avatar
Hi Guys, I noticed with my 02 lb7 that it starts hard at about 10 above if it sits all night, last year it started good all the time down to -10 below. It just turnes over and over and over. If I park the truck in the garage at night it is about 20 degrees in there it starts right up. I even put the light weight oil in it this year to see if it would help. When the truck starts it sounds like a old diesel tractor starting on only a couple cylinders then it revs up and smoothens right out. I put a new wix fuel filter on it too, no check engine light is on eather... what do you guys think???? Thanks
balance rates are good on the injectors, I am thinking if is somthing with the glowplugs, any ideas where to start? no codes are showing, thanks
2002 chevy Duramax ex. cab.
EFI live,
cold air intake,
turbo horn mod.
Snoman is offline
post #2 of 10 (permalink) Old 01-17-2011, 01:29 PM
rap2orrider660R's Avatar
Are you using any anti-gel, like Diesel Kleen ?
Aaron Blackwell
Cen-Tex Marine
Proudly Serving the Marine and Oil Industry
2007.5 D-MAX, EDGE DIGITAL GAUGES, QUADZILLA WITH DPF DELETE, TUNED AT 90HP NO MORE NO LESS, STRAIGHT PIPED, 17" CHROME SHAKER RIMS WITH 285 70 17 BFG KM2 MUD TERRAIN TIRES, AIR BOX MODIFIED,BUSHWACKER BED CAPS, RECON SMOKED LOW PROFILE CAB LIGHTS
rap2orrider660R is offline
post #3 of 10 (permalink) Old 01-17-2011, 01:56 PM
cherokeechief's Avatar
have you thought about plugging in the block heater?
if not, try this, turn key on til glow plug light goes out. turn it off and back to on again, til it goes out again, and repeat once more, then start it. if you do not plug it in.
cherokeechief is offline
post #4 of 10 (permalink) Old 01-17-2011, 03:02 PM Thread Starter
Snoman's Avatar
I have been running power service additive, I also cycled the key 3 or 4 times, If i plug it in it starts fine, but if i leave it sit at work i don't want to take the chance of it not starting. last year it started up to -10 with now problems had the batterys tested and they are fine.... Do you think if it was the glow plug rely it would show a code??? or not???
EFI live,
cold air intake,
turbo horn mod.
Snoman is offline
post #5 of 10 (permalink) Old 01-17-2011, 03:15 PM
05llysmoking's Avatar
thats crazy
some times under 20 degrees farenheit my glowplug lights doesnt even come on
if it comes on it wont stay on for more than 2 seconds
it fires right up no high idle or anything
you should plug it in
help the starter out
cause it isnt exactly cheap when you have to replace it!
2005 RCLB LLY
EFI Live/Gmax 5-3/Precision ML/SDP S475 Twin Kit/Lml Manifold/Egr Delete/Arp Studs/Downpipe/Mag Hytec Deep Pan /Fuel Lab Velocity 200/Ma Transfer Case Bracket/Ma Pump Rub/Yukon Grizzly Locker/Mag Hytec Deep Diff Pan/Mbrp 6' Black Mitre Cut
477/950 dynojet xdp open house rollers NO TWINS
Nitto 285/70/17 NBS rims
Autometer/Isspro 13.4 englishtown raceway
Limo Tint
Recon Cab Lights Smoked
Line X,Black Bowtie
05llysmoking is offline
post #6 of 10 (permalink) Old 01-17-2011, 03:17 PM
saw what you did there
theunderlord's Avatar
Originally Posted by Snoman View Post
Do you think if it was the glow plug relay it would show a code???
They usually do...
try scanning the truck anyway, you might have a MIL light problem... which is sorta common (read, cluster failure) on the older trucks.
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #7 of 10 (permalink) Old 01-17-2011, 04:13 PM
D-maxin's Avatar
Maybe two fresh batteries might help.
2002 LB7, Silverado 2500 CC LB
270,xxx miles on oringinal injectors
EFIlive, MBRP 4 inch, Ported intake horn
Black 20" Fuel Hostages, 33" Nitto Trail Grapplers, Ready Lift leveling kit
2011 LML, Silverado 2500 CC LB
Ready lift leveling kit
D-maxin is offline
post #8 of 10 (permalink) Old 01-17-2011, 04:22 PM
subscribed mine is deffinatly harder to start this year too only thing im doing different is im running hoews this year instead of power service
2003 GMC 2500 Big dipper trans, dual cp3, s366, EFIlive, trac bars, steering braces, lockers
1998 Dodge 2500 24v cummins BHAF 4" exhaust 6" stacks edge juice with attitude 6" procomp lift
1995 Doge 2500 12v Pump work hood stack
justinwilliamskx is offline
post #9 of 10 (permalink) Old 01-18-2011, 05:43 AM
I just had this problem as well.. get the glow plugs checked by a good diesel shop, not just one who will read codes. My glow plugs were disconnected at the first glow plug from the main power supply wire, no codes, no check engine light and dealer couldn't find it (yes they are that bad). Take a voltage meter and check to see that your glow plugs are getting power, you can get to them behind the fender, look like spark plugs but are all connected by a strip of metal (unless cali truck, then they are strung with wires). You can also check the voltage from the output posts on the control box, which is a little black box with 3 large wires coming from it located at the back of the engine, slightly on the drivers side against the fire wall. One wire comes from the battery, the other 2 supply the intake heater and glow plugs. Check each for voltage. May have a bad controller.. should be able to fix it from there. Or take it to a good shop that has someone besides a world of warcraft champion for a shop manager and can actually troubleshoot mechanical problems and not just plug in a computer.
martincc is offline
post #10 of 10 (permalink) Old 01-18-2011, 08:59 PM Thread Starter
Snoman's Avatar
Had the same problem as martincc, the wire was busted after the first glow plug then it burned out that glow plug too. I was changing the glowplug and i snapped it off. Now i have some more fun to deal with....LOL....
EFI live,
cold air intake,
turbo horn mod.
Snoman is offline
