My 03 wont reach normal operating temp - Chevy and GMC Duramax Diesel Forum
post #1 of 11 (permalink) Old 01-27-2011, 06:29 PM Thread Starter
Truck cranks fine but doesnt warn up until 15-20min of driving, and only warms up to about 185 degrees. Truck has low power until warming up. Any advise would be apperciated.
Hallen A$$ !
$cotty2Hotty6.6 is offline
post #2 of 11 (permalink) Old 01-27-2011, 06:31 PM
wheeler82's Avatar
as far as low power...could be allot of things i would suppose..first things first change ur fuel filter..could have got bad fuel...as far as temp..i think thats about normal..espeacially when its cold out thats all mine runs at...and being a diesel these do take some time to warm up.
-2007 GMC 2500 EXT.Cab short box
LBZ......love it so far!:rockin
wheeler82 is offline
post #3 of 11 (permalink) Old 01-27-2011, 06:31 PM
D-maxin's Avatar
What's the temperature there?
2002 LB7, Silverado 2500 CC LB
270,xxx miles on oringinal injectors
EFIlive, MBRP 4 inch, Ported intake horn
Black 20" Fuel Hostages, 33" Nitto Trail Grapplers, Ready Lift leveling kit
2011 LML, Silverado 2500 CC LB
Ready lift leveling kit
D-maxin is offline
post #4 of 11 (permalink) Old 01-27-2011, 06:41 PM Thread Starter
temp 24-50, plug it in every night, didnt have these prob. last year
Hallen A$$ !
post #5 of 11 (permalink) Old 01-27-2011, 06:43 PM Thread Starter
I have changed oil, and fuel filter, resent switch to Rotella Synthic.
Hallen A$$ !
post #6 of 11 (permalink) Old 01-27-2011, 06:43 PM
wheeler82's Avatar
any check engine lights?? could be a thermostat...u do eventually get heat though don't you?
post #7 of 11 (permalink) Old 01-27-2011, 06:54 PM
travis42's Avatar
I would say your thermostat is stuck open
Travis
2011 LML 3500 Dually
Full Delete
Farmtuned EFILive
5" Flo Pro
travis42 is offline
post #8 of 11 (permalink) Old 01-27-2011, 07:04 PM Thread Starter
I have heard 05s have 2 thermostats, do 03 have 2?
Hallen A$$ !
post #9 of 11 (permalink) Old 01-27-2011, 07:07 PM
XBoxLive: RenegadeDuramax
XtremeDMax's Avatar
Send a message via Yahoo to XtremeDMax
I would say you are experiencing normal behavior for a diesel in the winter.
You're "only reaching 185," because you're thermostats are 180* in the front and 185* in the rear.
Your "low power" symptom is caused by cold cylinders. Diesels like cold air in the intake, but the cylinder needs to be warm for proper combustion. The heat from the air/fuel being compressed is what drives your engine. It's not like a gas engine where there is a spark plug to detonate the fuel/air mixture. It's the compression that does it in our trucks.
You are experiencing normal conditions for the ambient air temp. Plug her in at night and she'll warm faster, but she'll still be cranky.
2015 Silverado 2500HD CCSB LTZ Dmax
Originally Posted by TheStepChild View Post
You want your exhaust to be like a fart. You can't see it but you know the effects of it.
If you can see your fart you got problems. If you can see your exhaust ...
XtremeDMax is offline
post #10 of 11 (permalink) Old 01-27-2011, 07:17 PM Thread Starter
thankx 4 all the help!
Hallen A$$ !
