Was driving home this morning when all of a sudden the battery, low fuel, and security started flashing on the dic screen. The water temp, transmission temp, fuel gauge and the volt meter also quite working. The abs, and the air bag light is on aswell. I have a cts2 and all of them are working correctly because I went though them and check it out. Also the PRND321 also isn't working. I checked all fuses, checked the ground under the cab. What's odd is my mph, and my tach still work. And it's also working down to the obd port because the cts2 is reading them just fine.
Would this be a bcm issue? Everything I've searched people have said that the cluster quits working all together, but a couple of mine seem to be working fine. While I was washing my floor mats I noticed that the floor board was wet ok the driver side (soaked through the carpet) I'm at a loss right now I've done as much as I can do with what I think could be wrong. Any help would greatly be appreciated.
