Hard starting when hot - Chevy and GMC Duramax Diesel Forum
post #1 of 3 (permalink) Old 03-04-2011, 01:37 PM Thread Starter
3-4-11
i have a 2003 gmc 2500 hd lb7 w/cal.emmissions completly stock 75000 miles
about 5 months ago i had a check engine light
code said glow plug
replaced "all 8 glowplugs" i cant be sure. After that it was hard starting.the dealer said they would diagnose it for free. In 3 hours first it was the fuel regulator then they called and said it was the injection pump and if i put up $1500 they would replce it and if that wasn't it they would give me my money back.i won't pay for parts changers
i took the truck home and found the short fuel line off the filter was cracked i replaced it and all was good for 2 months
now it starts cold after 5 second of cranking but when its hot it will crank but not start
any ideas out there
thanks for reading
jt
zbm2 is offline
post #2 of 3 (permalink) Old 03-04-2011, 06:04 PM
Having the same problem, dealer changed all injectors . No help with the start issue.
Added megafilter and lift pump. No help with start issue.
Changed most rubber fuel lines. No help yet.
2003 GMC 2500HD utility stock
Phil is offline
post #3 of 3 (permalink) Old 03-05-2011, 03:25 AM
mijdirtyjeep's Avatar
ZBM2's sounds like a classic case of injectors.
Personally I would put up the $1500 and let them put an injection pump in even though it might not be bad "they said they would not charge if it did not fix, and you get a new pump for nothing "
The reason they think the pump is bad is it probably will not reach commanded Mpa of at least 158-160Mpa. Shoot I put a new injection pump in a truck that at idle was around 26Mpa "3900psi", and at WOT could only muster 39Mpa "5800psi, that is just a little shy of the commanded 23000psi" Shoot this truck at WOT could only max out a little over what mine does at idle, and it never had a hard start condition
Jim
mijdirtyjeep is offline
