04, LB7. Tow/Haul was working fine till I wanted to pull boat home. Now neither Tow/Haul will kick in, nor will OD kick off. No lights come on dash. is there a fuse for that button?
The small wires that lead from the steering column up the shift lever to the button often break. They are orange (and white I believe) and I had to repair my numerous times. Take both the upper and lower steering column plastic covers off and you will see them.
I also have an lb7. If you remove plastic pieces u will be able to see the orange wires. Mine also stopped working, I used wire connectors to reconnect mine. I couldn't see buying a new shifter just for a broken wire.
206.6K members
