Cooling problem - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 03-25-2011, 07:46 AM Thread Starter
nymax's Avatar
Cooling problem
Hello . I have a 03 G.M.C . 2500HD with the Duramax . When Im running down the road at a normal speed the temp runs about 190 . When I start climbing a hill with it it will go up to 210 . It never overheats and very quickly cools back down after leveling out . I've changed Thermostats but it still happens . Not sure where to start . Any help would be great . Thank you .
nymax is offline
post #2 of 5 (permalink) Old 03-25-2011, 07:51 AM
MADMAXHD's Avatar
nymax - 190F to 210F is the normal operating range... keep on truck'n!
Dan
Previous 2003 GMC 2500HD CCSB
Current 07.5 2500HD LTZ NBS 6.0 Gasser CCLB BDS 7" Lift 20" KMC XD Rockstars, 37" Nitto Grapplers
Blackedout Grill and Bow Tie Debadged SuperChips LINQ
MADMAXHD is offline
post #3 of 5 (permalink) Old 03-25-2011, 07:56 AM
TJO116's Avatar
yup thats normal.. plus your temp gauge is more than likely off by like 5-10 degrees anyway.
2005 Silverado 2500HD Ext. Cab Long Bed
Mostly Stock
TJO116 is offline
post #4 of 5 (permalink) Old 03-25-2011, 08:13 AM Thread Starter
nymax's Avatar
I've owned the truck for 3 years now and it never wavered this quickly before . Even towing my loaded trailer . Its jumping fast . Im headed to Florida to pick up a 38 oldsmobile and am worried about overheating . It doesnt overheat It just heats up fast then drops quickly .
nymax is offline
post #5 of 5 (permalink) Old 03-25-2011, 08:14 AM
Administrator
jc1843's Avatar
Normal, but you want to make sure the "Stack" is clean-- AC condenser, inner cooler, and radiator. It may be full if dirt, leaves and bugs. And hot weather is coming.
jc1843 is online now
