LB7 stalls when cold.. Please help - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 03-26-2011, 03:06 PM Thread Starter
Ive got an 04 LB7. The problem is on cold mornings (20's-30's) ill go out to start my truck and ill let the glow plugs cycle then it will fire right up run for 10-15 seconds and run itself out of fuel. once it does this you can crank till you run the batteries dead it will not fire, the only way itll start up once it quits is you push the primer pump 5-6 times till its hard then it will fire right up and run great the rest of the day no matter how many times you shut it off and re-start it. and its not an everyday thing. It might happen two mornings in a row, or it might be fine for a week. At first i thought it may me the cp3 pump going, but i got thinking if that was the case the thing would run like shit and have that problem all the time. So now i think its the Fuel pressure regulator. Im not fimilar with the duramax's bc they never break down haha, now powerstrokes on the other hand im great with.. I was wondering anyone had ever heard of this or had run into this or may have some suggestions since ive read changing the fuel pressure regualtor isnt an easy task.. now ive also got a check engine light on but thats bc my #8 glow plug is bad and has been for over a year, just been too lazy to change it and it starts great anyways. any help would be greatly appreciated thank you
04 LB7
33/12.50 17 mickey thompson mtz
edge w/ attitude
intake mod
halo headlights and parking lights
led cab lights
4 inch turbo back strait pipe with 7" tip
chevyboy9880 is offline
post #2 of 6 (permalink) Old 03-26-2011, 05:06 PM
Earnhardtfan's Avatar
Ever plug it in a night? Sounds like your loosing prime somewhere. Check your fuel filter and filter housing. Two places where a leak could be due to o-ring failing.
Justin 2001 LB7 Silverado 2500HD LT CCSB 4x4.
EFI Live by Idaho Rob, 443K+ and rolling, Undercover Bed Cover, Vortex spray in bed liner, Odyssey Extreme Batteries, Westin steps, Bilstein Shocks, Road Master Active Suspension, M/A Pump Rub Kit, PPE Trans Cooler, MBRP 5" Exhaust, Edge Insight CTS, K&N drop in filter, AirDog II 100 w/ CAT 751, LLY FF Housing w/ Racor, Running on LMM Blacked out Wheels & Michelin LTX M/S2 tires.
ADRENALINE TRUCK PERFORMANCE
Lincoln Diesel Specialties
Merchant Automotive
Earnhardtfan is offline
post #3 of 6 (permalink) Old 03-26-2011, 05:10 PM
You could have a air leak in your fuel line from your tank so after sitting a while your fuel drains back into your tank and you lose prime. Once you get it started you probably dont have this issue because it doesnt sit long enough to lose prime. Im thinking the cold has nothing to do with it.
2013 GMC SLT LML-Cogntio 4-6" NTBD lift with fox 2.0 shocks,Cognito pitman and idler arm supports, Cognito UCA's, ADII 165, autometer colbalt pryo, boost guage, and CTS insight, full egr delete with 3" downpipe and LB7 uppipe, 5" flo pro exhaust, PPEI tuning,Wherli S475 over stock twins
MADD*MAX is offline
post #4 of 6 (permalink) Old 03-28-2011, 04:38 AM Thread Starter
if i had an air leak wouldnt i also have a fuel leak as well? it wierd, the truck sat most of the week and friday it fired right up with no problem
04 LB7
edge w/ attitude
intake mod
led cab lights
post #5 of 6 (permalink) Old 03-28-2011, 05:56 AM
duramaxx90's Avatar
I had the same exact problem with my 03 lb7 and everyone said it was either a hole in my lines or my fuel pressure regulator. But i went ang put an airdog lift pump on there and it never did it again. Im in alaska so its almost always cold and its been 6 months now without a problem
03 2500 4x4 Bullydog power pup, MBRP 4in straight piped with 5in tip, volant cold air intake, PPE boost increase valve, Airdog 2 165 GPH, 8in Fabtech lift, 37in BF Goodwrench MTZ on 17in ATX rims :rockin
duramaxx90 is offline
post #6 of 6 (permalink) Old 03-28-2011, 10:56 AM
Unless you have a lift pump, the fuel isn't under any pressure until after the cp3. The cp3 creates suction which pulls the fuel from the tank to the engine. A small leak on the suction side would not leak fuel out, but could very well allow air into the system.
I was having this problem for awhile. I could drive for two or three days without an issue, and then it just wouldn't start. Priming would correct the problem. I traced it to a leaky bleeder screw o-ring. I had already ordered a replacement aluminum screw, that hadn't arrived yet, so I took the old o-ring off and found a suitable replacement at a local auto parts store. That solved the problem until my shiny new replacement screw showed up.
2002 Pewter CCLB - 4x4 - LB7 - AirDog II - Rancho 9000's - New injectors at 147k - Access Tonneau - B&W Turn-over ball - ATS Stage I Transmission - ATS 5 Star Torque Converter - ATS Pump Rub Kit - ATS E-Power - New Rear Transfer Case Half (pump rub hole) - Edge Insight CS
HDBrad is offline
