01 LB7 To 77 body 73 Frame Chevy k10 - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 05-19-2017, 08:21 PM Thread Starter
So, on the 13th of May 2017, I was T-Boned by a Driver who ran a red light in my 2001 Duramax Crew Cab Longbox LT. and totaled the truck And I've had this plow truck laying around and I'm wondering what it would take ti putt that motor and tranny inside that truck? and where do tranny wires and everything run? and could it be broken and messed up? Please more people the better.
Jakeander24 is offline
post #2 of 6 (permalink) Old 05-21-2017, 02:25 PM
t.ashton's Avatar
That is a ba swap, you can do it but you will need a good amount of fabricating for mounts and such
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, DSP 5 on v2 by Rick Fletes, 33x12.5 nittos at on 20 inch American steal wheels, modded factory air box, Profab Intake Horn, Batmo Wheel, Turbo port and polish, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust, 10mm lbz cp3 pump, Dual Yellow Top Optimas, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Contol arms, Drilled and Slotted Rotors on all four Corners, Custom Y Bridge.
t.ashton is offline
post #3 of 6 (permalink) Old 05-21-2017, 02:48 PM Thread Starter
Well, I found mounts and trans cross member made by Precision Fabrication DURAMAX DIESEL ENGINE CONVERSION Wondering if that would work, And what would I have to swap over do i need to use the 2001 dash or would i be able to keep the dash in the 77?
post #4 of 6 (permalink) Old Yesterday, 04:55 AM
t.ashton's Avatar
Dash isn't important, you do have to keep your gauge cluster and all engine electronics like you ecm, tcm, and your full harness.
t.ashton is offline
post #5 of 6 (permalink) Old Yesterday, 04:56 AM
t.ashton's Avatar
And the kits was designed for it so it will definitely work.
t.ashton is offline
post #6 of 6 (permalink) Old Yesterday, 05:27 AM Thread Starter
So I'd need the 2001 gauge cluster I couldn't keep the 77 gauge cluster that is inside?
