fuel temp sensor??? - Chevy and GMC Duramax Diesel Forum
Old 03-31-2011, 06:21 AM   eBay Motors  #1 (permalink)
evansdmax's Avatar
fuel temp sensor???
ok i'm geting code p0168 and p0181 and i went to carquest to get a fuel temp sensor bc i thought thats what it was... but they don't list one and neither does gm.. but they show a fuel pressure sensor and a coolant sensor... what ya'll think? it surges on the interstate some and skips when it's cold more than when it's hot i can clear the code and it comes right back... sometimes it willrun better than others but not at specific times....?? i wanna get it fixed today bc i'm off work if i can figure out what to do.
03 CCSB EFI + 5" STRAIGHT PIPE + 33X12.50 18S ON EAGLE ALLOY 197'S + 250K MILES
evansdmax is offline   Reply With Quote
Old 03-31-2011, 06:59 AM   eBay Motors  #2 (permalink)
evansdmax's Avatar
anybody? bump to the top for some answers
Old 03-31-2011, 07:42 AM   eBay Motors  #3 (permalink)
evansdmax's Avatar
nobody had any problems with this?
Old 03-31-2011, 08:06 AM   eBay Motors  #4 (permalink)
TrevorG's Avatar
If it's surging at idle I'd almost say it's your fpr.. But bump for an answer
Trevor, 18
2005 GMC Sierra 2500HD Duramax Diesel EC/SB
Resonator Blocked, EGR Blocked, PCV Rerouted, Tie Rods Sleeved
LBZ MP, 5" Turbo Back, 6" Tip, Cobalt Boost & Pyro, Leveled on 33's
ATP EFI DSP5, Profab Downpipe, Raptor 150, Custom Dying Allison
Originally Posted by bigbaddiesel View Post
If anyone chains up..Put a good 1000lbs of something in the back first.. Or get 4 of your most overweight buddies to come along...Offer them snacks if it helps to get them in your truck.
TrevorG is offline   Reply With Quote
Old 03-31-2011, 08:22 AM   eBay Motors  #5 (permalink)
Pura.Vida's Avatar
I had mine throw a code, but I reset it and rolled on with it and have not had any problems since. My mechanic at the dealership told me he had never replaced one or seen that code, and could not find it in the parts list to even order it.
You should do a search, I have started a big thread about this, and so has one other person. No reason to start this one, just join in on another one already going, you will get more help that way because of the subscriptions already going.
Jordan
05 LLY CC SB 4X4, K&N ON LBZ INTAKE, RESONATOR PLUG, LBZ MP, 4" SILVERLINE, PCV RE-ROUTE, PORTED FUEL RAIL FITTING, EGR DELETE TUBE, FPRV SHIMMED, AIR DOG II 165, DEEP PAN/FILTER LOCK, TRANS-GO JR SHIFT KIT, SYN BLEND TRANS FLUID, PPE STANDARD, H2 WHEELS WRAPPED IN 295 GRAPS, HID H/L/F ALL ON, LED PLATE LIGHTS, MANUAL HIGH IDLE, GATORBACK SERP BELT, TORSION KEYS, TIE ROD SLEEVES, ARP HEAD STUDS
Oxcart- 01-18-2011, 11:43 PM
Thread-efi smoke tune help
"You will be back hippy."
Pura.Vida is offline   Reply With Quote
Old 03-31-2011, 08:43 AM   eBay Motors  #6 (permalink)
jcbDuramax's Avatar
yulp same code, still no answers thou. im showing more symtoms then you are thou. i have the ppe race vavle so im doubting the FPR on mine
2007 chevy lmm LTZ
Z71 midnight blue
4" mbrp dsp5 egr block bf al terrains .
RIP - 05 LLY and Allison 5spd
[/B]
Originally Posted by RedBowTies88;6Z28261
efilive is the easy way out...diehard smokers break out the butt connectors and get shit done
Z
jcbDuramax is offline   Reply With Quote
Old 03-31-2011, 08:46 AM   eBay Motors  #7 (permalink)
Longbeds FTW
DMAXchris's Avatar
It can also be called a fuel rail temperature sensor I guess. I found this info while searching around...
Fuel Rail Temperature (FRT) sensor
Mounted under the turbocharged air outlet duct, the FRT sensor is a two-wire Negative Temperature Coefficient thermistor that the ECM uses to monitor fuel temperature. Because the fuel passes through a small radiator-style cooler (mounted underneath the cab), check for clogged cooler fins if the fuel temperature climbs too high.
http://www.google.com/search?hl=en&d...509fc152d027c3
06 Dmax/Allison EC/LB 4x4
TTS PowerLoader III • full billet Bully Dog stage 7 • BCI 7" intake with custom snorkle • fender vents • quintuplet shotgun cat stacks • 22" Rockstars • Huge "Dirtymax" sticker • -60% nozzles • extra pcv with dual catch cans • compounded EGR • silencer ring MIA • 4.56 gears • Lowered 5.5" in the back • Lifted 6" in the front • Monster sticker • flat bill mod • 8' CB whip • blacked out reverse lights • gauges everywhere
08 BMW 528xi
00 Buick Regal GS
DMAXchris is offline   Reply With Quote
Old 03-31-2011, 08:50 AM   eBay Motors  #8 (permalink)
jcbDuramax's Avatar
thanks for the info. that gets me looking in one direction...but currently all the symptoms have seized to exist so i cant trouble shoot anymore until they come back...maybe it only happens in cold weather.
2007 chevy lmm LTZ
Z71 midnight blue
[/B]
Z
Old 03-31-2011, 08:51 AM   eBay Motors  #9 (permalink)
Longbeds FTW
DMAXchris's Avatar
I read that it can happen sometimes when using the block heater or grille cover below 0ºF.
08 BMW 528xi
00 Buick Regal GS
Old 03-31-2011, 01:05 PM   eBay Motors  #10 (permalink)
evansdmax's Avatar
Ok thanks my block heater has never ever been used on my truck and is a southern truck so it doesn't get to cold! it acts like a sensor I'm gonna do not searching thanks guys.
