Fan pully bearing????? - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 04-02-2011, 07:03 PM Thread Starter
gofastorbelast14's Avatar
ok so my fan pully bearing in my truck is going out, its not the fan clutch and not the idler pully. The thing is making a lot of noise anybody raplace one before??? anyone know if u can do it without pullin the radiator???
04 lb7 Edge Juice with attitude programmer, 4in magnaflow stainless exuast, Banks ram air intake.
gofastorbelast14 is offline
post #2 of 7 (permalink) Old 04-02-2011, 07:05 PM
blackdeath's Avatar
a fan pulley bearing ???? what is that, its the clutch or water pump,, tensioner and idler have a bearing, alternator and scraem too
blackdeath is offline
post #3 of 7 (permalink) Old 04-02-2011, 07:08 PM Thread Starter
ha i guess its the bearing behind the fan pully?? does that sound right
post #4 of 7 (permalink) Old 04-02-2011, 07:17 PM
i changed my water pump without removing the radiator,just need a clutch fan wrench to remove the fan only a few bolt hold the bearing assembly to the front of the motor
02 ccsb performancetruckproducts.com
addelo6 is offline
post #5 of 7 (permalink) Old 04-02-2011, 07:23 PM Thread Starter
i was under the impression that the water pump on the duramax was gear driven and that there was just a sealed bearing behind the fan assembly
post #6 of 7 (permalink) Old 04-02-2011, 07:25 PM
you are correct, i was just relating to a far worse job without removing radiator
addelo6 is offline
post #7 of 7 (permalink) Old 04-03-2011, 02:05 AM
blackdeath's Avatar
sorry yea u correct , i just really didnt put 2 and 2 together there , wording sh&t the wrong way my bad
