Front end "thumping" sound - Chevy and GMC Duramax Diesel Forum
post #1 of 13 (permalink) Old 04-08-2011, 08:56 AM Thread Starter
Please excuse the long write up. I want to ensure you have all the info.
I have put in new ball joints about 10-15K ago. After I returned from my deployment, I noticed a thumping noise in the front end of my truck when I went over bumps. I had the front end inspected and replaced inner and outer tie rods and idler arm. When I had the allignment done, I had a different tire shop do an inspection on the truck and they said the front end suspention looks great.
The stearing wheel was pretty loose when I started, but tightened up a little bit after I replaced the parts and had an allignment. It's still a little sloppy but it's a truck and I plan to have the intermediate drive shaft inspected.
In the process of all this, I looked at the lower A Arm and it looks as though the bump stop is contacting it on a regular basis. I is creal where as the rest of the A Arm has typical dirt and dust. I'm assuming this is my thumping noise by the front tires. Any suggestions would be appreciated on a culprit. The only thought I have is the Torsion Springs need to be adjusted, if that's a typical adjust ment that needs to be made. Thanks in advance for your help.
03 CrewCab LT, Long bed, Cab high topper, 265/70/17 Michelin LTX MS2 tires, Intake Horn Mod, EFI Live by Idaho Rob, PPE Boost Valve, Stainless Steel brake lines; Trans built by Mike L.
reifwj is offline
post #2 of 13 (permalink) Old 04-08-2011, 09:03 AM
Recovering Diesel Addict
KryPTiC's Avatar
Could be the intermediate steering shaft, cab mounts, maybe a bad shock? the bump stop on the lower a-arm is supposed to touch when the suspension works, it should be soft enough to not make a thump tho.
Dale
- 2003 GMC CCSB -
Performance: EFILive by Rob•DSP5•S&B Intake•Profab Downpipe•Straight Pipe
GMax-5(built by me)•1056•Lift pump•PPE Boost Valve
Exterior: Cowl hood•Halos with HID•Clear Signals•Vertical Grill•Tri-Fold Tonneau Cover
Custom Slip Tank•LED Tail Lights•Painted to Match Vent Visors•Chrome Running Boards
Debadged•Tint•Fuel Octane 18's with 35's•Cognito 7" Lift•Cognito UCA•Dual Shock Hoops•Bilsteins
6" Deavers•Firestone 9000 bags
Interior: Autometer 3 Gauge Pillar•Ultra-Lite II Boost and Pyro•Aeroforce Interceptor
US Speedo•Pioneer Deck•MTX 1200 Watt Amp•2-10" MTX Subs
To Come: Twins•Bigger Fire Sticks•Front & Rear Bumpers Built by Me
Fresh Paint
KryPTiC is offline
post #3 of 13 (permalink) Old 04-08-2011, 09:45 AM Thread Starter
Sorry forgot to mention new front shocks as well.
reifwj is offline
post #4 of 13 (permalink) Old 04-08-2011, 09:53 AM
mxhead6.6's Avatar
is it a thumping noise? or a knocking noise..i had the same issue.. and it was blown shocks in the front...but like you said you have new shocks..so im not sure
2006 silverado 2500hd loaded,blue LED conversion, cobalts, CTS,6'' skyjacker, softride springs
mbrp down pipe, 4'' straight pipe, 7''mbrp stack,
EFI live DSP5
Ignited 8000k low beams, highbeams, fogs.Banks ram air,bushwaker fender flairs,35'' Nitto Mud Grapplers
RBP 18'' 94r's, RBP RX-2 running boards, RBP RX HD Grille,BD turbo gaurd,Airdog2 165,Longhorn Fab Shop trac bars,alpine 7'' double din, 2 Type S's under the rear seat,trainhorn
Tranny and spinny thing to come!
mxhead6.6 is offline
post #5 of 13 (permalink) Old 04-08-2011, 09:58 AM Thread Starter
It's a thumping noise like a ball joint. When I replaced the tie rods it happens less and isn't as loud, but still there.
reifwj is offline
post #6 of 13 (permalink) Old 04-08-2011, 10:15 AM
Maybe a loose/worn out wheel bearing?
2002 Pewter CCLB - 4x4 - LB7 - AirDog II - Rancho 9000's - New injectors at 147k - Access Tonneau - B&W Turn-over ball - ATS Stage I Transmission - ATS 5 Star Torque Converter - ATS Pump Rub Kit - ATS E-Power - New Rear Transfer Case Half (pump rub hole) - Edge Insight CS
HDBrad is offline
post #7 of 13 (permalink) Old 04-08-2011, 10:40 AM Thread Starter
I replaced driver's side wheel bearing when I did the ball joints. I think that's everything. Thanks for your help so far.
reifwj is offline
post #8 of 13 (permalink) Old 04-08-2011, 02:26 PM Thread Starter
Shook the steering shaft and I could duplicate the noise by shaking the crap out of it. Will this also tighten up the play in the steering wheel?
reifwj is offline
post #9 of 13 (permalink) Old 04-08-2011, 03:16 PM
it stinks and whistles :)
Brennan's Avatar
The steering shaft is a ridiculous problem on the half tons, not sure on the 3/4 and 1 tons tho
06 lly,
Efi From ATP trucks,
5" straight pipe, egr blocked, cognito ucas,
rare parts gen2, bilstein 5100s, all season brace,
merchant pump rub fix, drp trans cooler lines,
air dogII 165
Brennan is offline
post #10 of 13 (permalink) Old 04-08-2011, 03:50 PM
mikeyg's Avatar
i would bet its the upper a-arm hitting the stop. Mine does the same thing, what happens is when the suspension hits full extension, the upper a-arm hits the stop, and unlike the bump stop for full compression that has a rubber stop, the extension is just a steel plate, so it makes a pretty loud bang. Mine did it after putting new torsion keys in it.
mikeyg is offline
