where to tap for my boost gauge? - Chevy and GMC Duramax Diesel Forum
post #1 of 11 (permalink) Old 04-14-2011, 10:25 PM Thread Starter
Hartdiesel's Avatar
I just got some ditigal autometers and need to know the best place to drill and tap for my boost gauge i cant tap into the vacumm line cause of the sensor next best spot? picutres would be great
2002 gmc crew cab shorty leveled on twentys
-Efi Live w tunes from Vegas
-5 inch turbo back MBRP
-Autometer ditigal cobalts on the pillar
-PPE stage IV trans built by me
-AD II 165
-tie rod sleeves
Hartdiesel is offline
post #2 of 11 (permalink) Old 04-14-2011, 10:31 PM
Banned
Get a SD manifold Mang.
SoCal Diesel - Boost Manifold
Hondarider552 is offline
post #3 of 11 (permalink) Old 04-14-2011, 10:34 PM
BoostJunky's Avatar
You can't tap in to the vac line bc of what? Our models are the easiest to do. All you need is a knife, screwdriver and 5 minutes...
07.5 6.7 Cummins MC/SB
EFI, ARP, SC Comp 68, FASS, HTT Stainless, Borg Warner, Diamond Eye, and a lot more...
-2002 cc/sb SOLD
|4.5" on 34's|18" Moto Metal 961's|PPE 160 Tune|S&B CAI|5" Straight Pipe w/ 7" Tip|Ported/Polished Intake Horn|PPE BIV|PPE CP3 Fitting|Autometer Cobalt Boost/Pyro|Sleeves|Bushwackers|Kenwood 2xDin|Headrest DVDs|Boston Components|10's, JL 500/1 & 300/4|Black Halo Projectors w/ 6k/8k HIDs|Billet Grille|5% Tint|'03+ LED Tail Lights|Clifford Security System|Valentine One
BoostJunky is offline
post #4 of 11 (permalink) Old 04-14-2011, 10:36 PM
Im Superrrrr!
jmaz268's Avatar
Send a message via Yahoo to jmaz268
I prefer mine as well.....I like to know whats entering the motor and not off the turbo, easier to diagnose a lose in psi as well.
Goes by John
--2001 ECSB
SDP Big Single, Wehrli Dual Fuelers, 50% sticks, Front Coilover Conversion, Anorexic .....much much more
Sponsored by Creatures of the Night Performance and SDP
--2005 CCLB Dually
The tow pig
Tuned and Edge Insight CTS
jmaz268 is offline
post #5 of 11 (permalink) Old 04-15-2011, 06:34 PM Thread Starter
Hartdiesel's Avatar
Cant tap into the vac line because i can not find a brass T anywhere with a 1/8" npt FEMALE on it. Has to be this way because its a DITIGAL gauge so it uses a sender.
And thanks brian ive never seen those before....little more expensive then i was hoping for though
-AD II 165
-tie rod sleeves
post #6 of 11 (permalink) Old 04-16-2011, 06:43 AM
BoostJunky's Avatar
Ahhh, i gotcha. Did you hit up lowes and home depot and Ace Hardware?
-2002 cc/sb SOLD
post #7 of 11 (permalink) Old 04-19-2011, 04:20 PM
paintballrepins's Avatar
Use a brass T with 1/8in npt female on all three sides, then get 1/8in male fittings. for the hose ends.
I think alligator performance sells a boost hose with a tap in it as well, post cac.
Chris
My truck/DD: 97 GMC 2500 Reg Cab (6.5 + 0.1 = LB7)
EFI Live Tuned, 6" RCD Lift, Rockford Fosgate 600 watt system, SB DD Clutch/NV4500
The Car/DD: 08 Lancer
Tech Package, Rockford Fosgate System
Farm Truck: 01 Chevy 2500 Reg Cab
EFI live by Duramaxtuner
Performance Truck Parts
paintballrepins is offline
post #8 of 11 (permalink) Old 04-20-2011, 07:34 PM Thread Starter
Hartdiesel's Avatar
tried all the local home depots exc. but no worries was in tacoma and stopped by baxter and picked up a brass t and two barbed males thanks for trying till i figured it out boys haha
-AD II 165
-tie rod sleeves
post #9 of 11 (permalink) Old 05-04-2011, 10:28 AM
01 T/A's Avatar
can some one post a pic of where you guys are putting this in i have a new glow shift i want to get in and just not sure.
2001 gmc 3500 ext. cab duelly auto. mbrp 5" turbo back, ppe biv, pump rub fix, ats diff cover, amsoil in all, alligater turbo horn, airaid cai, and ranco 9000XL's, ARP head studs.
GM DRW club member #7
01 T/A is offline
post #10 of 11 (permalink) Old 05-05-2011, 09:31 AM
lb7smoke's Avatar
im tapped in between the compressor housing and wastegate
2015 Denali Duramax... Stock for now
lb7smoke is offline
