Tow Haul OD Button not working - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 05-26-2011, 11:16 AM Thread Starter
Pat@BD's Avatar
I have heard this is not a really common problem, but it does happen. I have been told that over time the wire that runs from the tow haul button can break. Now to replace it I have been told to just switch it to a new shifter. Has anyone done this? What am I in for? Thanks in advance for any answers.
Pat Stewart
Technical Sales
BD Power
www.dieselperformance.com
800-887-5030 ext. 101
2003 Chevy 2500 BD Valvebody, Edge juice CTS Hot, Volant air intake, BD 4" Dual exhaust. BD Exhaust Brake more to come....
Pat@BD is offline
post #2 of 6 (permalink) Old 05-26-2011, 11:32 AM
I have had this happen on my old '02 1500 and my old '02 tahoe, It looked like what happened was that the wire was pinched in two. I just popped the shift boot out and maybe the bottom half of the steering column cover and stripped the orange wire exposing the red and black stripped those and soldered them back together and taped them up and taped them up out of the way so they don't pinch again.
hope that helps
Daniel P. is offline
post #3 of 6 (permalink) Old 05-26-2011, 12:05 PM Thread Starter
Pat@BD's Avatar
Thanks. I was going to try that, but I had heard it was easier to replace shifter. I will have a look tonight. thanks again.
Pat Stewart
Technical Sales
BD Power
Pat@BD is offline
post #4 of 6 (permalink) Old 05-26-2011, 02:59 PM
My uncle had this happen recently on his 05. There are 2 tiny wires that go to the tow/haul button and provide a temporary ground. One of his wires was broken somewhere on the shift lever. he was able to remove the shift lever and repair the broken wire and its been fine.
FYI.....my cost on a new shift lever was like 85 bucks.
2004 GMC Sierra LB7: stock
VtecGSR95 is offline
post #5 of 6 (permalink) Old 08-18-2011, 05:40 PM
just replaced one wire in lever by adding a short piece to the broken one and soldering it in.In my opinion this is an engineering fault that should have been repaired free of charge.This fixed the tow/haul mode
cranky is offline
post #6 of 6 (permalink) Old 08-18-2011, 05:45 PM
LHN...We ARE the Joneses
Originally Posted by cranky View Post
...In my opinion this is an engineering fault
Just curious...Do you have a lot of column Tilt action going on? Or does the angle get set and left alone?
Hook'em_Horns! is online now
