LB7 fuel mileage - Chevy and GMC Duramax Diesel Forum
post #1 of 51 (permalink) Old 05-31-2011, 02:50 PM Thread Starter
LB7 fuel mileage
hi i have heard of the lb7 getting up to 23-24 highway talked to guys that get 22 all the time but also guys that havent seen past 16 highway. and that you can get a good one or a bad one. is there anything i can do to get even the upper teens to twenty. i currently get 13.5 in town. and with a gooseneck with 2 f250s on it i didnt see better than 9.5 on the highway. please help.
03 duramax, 115000 miles, hypertech chip on stage 2, 4 in exhaust, spectre cold air intake, and 33 mud tires
03-dirtymax is offline
post #2 of 51 (permalink) Old 05-31-2011, 03:10 PM
And I be smokin
trublulb7's Avatar
Don't know to much about the hypertech but I think you should start there. I have a triple GT and I get 20 to 21 on the highway with 35's. I'm ordering EFI tomorrow so I'm hoping to see even more of an improvement, In town my mileage sucks getting moving kills me. I would Imagine going back to 285's would help you as we'll. I would also Clean your MAF sensor probably won't do much but It won't hurt anything either.
Jeff | 03 LB7 ECSB in Arrival Blue | 6" Fabtech | Tierods/Braces | Airaid Intake | 4" T.B/muffler delete | Profab Intake horn and D.P | Pump Rub Kit | BD Deep Pan | PPE B.V | EFI tuned by Mr. Coddens | AirdogII | Upgraded Sound | 20x10 MKW M26 | 35x12.50 Toyo M/T's | Bushwacker | 15% | All on Mod |
trublulb7 is offline
post #3 of 51 (permalink) Old 05-31-2011, 04:23 PM
Just Pin It!!'s Avatar
Well I'm one of those guys that use to only get 12mpg in town and 14mpg on highway, but grant it I'm a dually. I put a K&N cold air intake on and that put me up 1/2-1mpg at both in town and highway. I used my buddies bullydog to try it out just to see if I could improve some before buying something since I'm new to this I figure it wouldn't hurt to try something. And that worked, I got 15mpg around town and 16.5 on the highway for a short run. This past weekend I just installed a 4" stainless exhaust on and I can't wait to see what happens with it. Then I just purchased a Stealth2 from someone and everybody says that will do even better than the BullyDog, so I'm even more excited. I will keep everyone posted on the out comes.
'02 LB7 3500 CC/LB dually
K&N cold air intake
4" Stainless Exhaust by Pypes Performance
Just installed Quadzilla Stealth2......
looking to do other mods for some gas mileage... any suggestions needed if you have the same truck...
Just Pin It!! is offline
post #4 of 51 (permalink) Old 05-31-2011, 05:32 PM
I had an 03 6 in lift, 22" wheels, and thirty fives. Put PPE level 5 and MBRP 5" exhaust and id get 22 all day long on the highway and 19 - 20 city if i wasnt sitting still for too long.
2006 Chevy 2500HD CCSB
20" Wheels, 5" MBRP Exhaust w/ 7" MBRP Tip. STAY TUNED - MORE TO COME
jester296 is offline
post #5 of 51 (permalink) Old 06-01-2011, 07:00 PM
mikeyg's Avatar
I highly doubt anyone gets 23-24 period. People often forget to re-calibrate speedos for bigger or smaller tires. It seems u have just about everything u need for a little better milage, programmer, intake and exhaust. Just make sure your speedo is adjusted for 33s. You can also look intoo water/meth injection, which will add a few mpg, and u r looking for real world mpg, not a one time trip with absolute perfect condition
mikeyg is offline
post #6 of 51 (permalink) Old 06-02-2011, 05:29 PM
shrummyboy's Avatar
my truck on 37s got 300 miles on half a tank, correct me if im wrong but thats 13 gallons (stock tank) all i have is a superchip on max performance, quadzilla air intake and straight piped stock exhaust. thats 23 mpg with the speedo set for my tires
03 Chevrolet 2500HD LB7 crew cab short bed
6" rough country lift
3" body lift
37x12.50x20 Nitto Trail Grappler MT
20x12 Black Fuel Octanes
3.5" straight piped exhaust
quadzilla monster air intake
superchip pogrammer high performance mode
shrummyboy is offline
post #7 of 51 (permalink) Old 06-02-2011, 05:40 PM
lb7smoke's Avatar
ditch the hypermax, im getting just about 22-23mpg on my setup as it sits if i can keep my foot out of it
2015 Denali Duramax... Stock for now
lb7smoke is offline
post #8 of 51 (permalink) Old 06-02-2011, 05:48 PM
roxyfever's Avatar
my mods with a efi 90hp tune at 65mph I get 23 on highway and a high intown of 18.5 on same tune
2003 ford explorer v6
Wifes ride/2009 6.4 F350 SRW CCLB 4x4 135k
roxyfever is offline
post #9 of 51 (permalink) Old 06-02-2011, 05:53 PM
realwhiteman's Avatar
Most don't do much better than 300 miles on a full tank on the average, thats a fact. Some must be easier on the go pedal or not good with math. I can get my DIC to read 20 - 22 all day long, but long hand is about 15-17 on the average running 2200 rpm. Its more about your style of driving, not what you have for power adder.
2004 LLY 2500 HD
LBZ MP, LBZ S&B Cold Air Intake - Dry Filter
Raptor 150/Nicktane/CAT Combo
5 inch Turbo back, no muffler
realwhiteman is offline
post #10 of 51 (permalink) Old 06-02-2011, 06:29 PM
lddrew's Avatar
no offense but measuring how many gallons you burn by the fuel gauge is pointless. my fuel gauge is so erratic. it drops to 3/4 fast, but stays below 1/4 forever. and my low fuel light comes on there is still 6-8 gals in the tank.
the ONLY way to accurately measure fuel mileage is topping off the tank to where you can see it, driving with your speedometer reading correctly, then refilling to where you can see it and divide how many miles you drove by how many gallons put in.
it seems like a lot of guys are all conjecture on what their trucks should get and what the DIC says and yadda yadda yadda. maybe b/c they know it won't actually calculate to that if they do it the for real way. there's no excuse not to actually calculate your mileage right.
here's a great tool i recently found you guys should check out if your serious about tracking mpg's
Fuelly | Share and Compare Your MPG
I seriously doubt a 7-8,xxx lb vehicle gets 19-20 in town.... maybe 15-16. if they do more power to you. but seriously
-Lee-
LBZ Crew - EFI - MBRP - Profab - Airdog
Raptor lined rockers and flares by me
my "build" thread
Raptor color match thread
ATP Trucks
lddrew is offline
