| Junior Member | Crank position Sensor Replacement Hey guys, What is the easiest and fastest way to change out the crank position sensor? Facing the engine, its on the left side by the balance right???
__________________ 2001 2500HD 6.6 Duramax 216,500 miles with no programmer |
| Offical LB7 "Tech" Join Date: Sep 2010 Location: Saint Johnsville, NY
| X2^^^ Bump for this! I need to replace mine today...
__________________ -Aaron- 2001 GMC Sierra 2500HD, Limited Edition, CC,SB EFI Live V2 w/dsp5 MAX EFFORT by Idaho Rob, EGT's Never higher than 1150* Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, BATMO, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler- Wastegate, FASS 150, LBZ FPR, Shimmed FPRV, Built Trans, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler @180,000-New injectors from Lincoln Diesel, CAT Adapter/filter/spacer Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires, MANY More extras inside... ![]() |
| Junior Member Join Date: Aug 2011
| bump? anyone have a part number for an LB7? |
| Junior Member Join Date: Oct 2011 Location: Bradenton, Florida
| I dont know what the easiest way to change it is but I can tell you that it is on the left side when facing the motor and the part # is 2536649. EDIT: The AC-Delco # is 2134277 the first one is the GM number
__________________ 2009 ccsb 4x4 Not Stock No More |
| Yup, thanks guys. Just found out that info myself. Here's a picture: P0335 Crankshaft Position Sensor - TheDieselPage.com Forums The best price I found on the sensor was $60, $63 shipped from Rock Auto. The local dealer wanted $135.. |
