Noisy injector - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 06-09-2011, 10:01 AM Thread Starter
JJ78040's Avatar
Noisy injector
changed one of my injectors and now its real noisy, wasn't noisy before so i'm thinking its the new injector, is this normal or did i get a bad injector, can't really hear it at idle but once you accelarate it gets real loud
04 LB7
CREW CAB 4X4
HYPERTECH PROGRAMER
17'' WHEELS ON 35'S
JJ78040 is offline
post #2 of 8 (permalink) Old 06-09-2011, 10:07 AM
taylorbok's Avatar
most people say dont change just one injector, do the whole bank if you are going through the hastle
2007.5 lmm CCSB black, bullet proof bumpers.
efi live (motor ops), cts insight, 5" straight pipe, 7" bds lift, 37" toyos on fuel maverick, egr blocker,
taylorbok is offline
post #3 of 8 (permalink) Old 06-09-2011, 08:35 PM Thread Starter
JJ78040's Avatar
ok opened up the hood and the sound doesn't seem to be coming from the injector, you can hear it more from the inner fender on the drivers side and the bottom of the truck, did some research and could be "pilot injection" heard you can disconnect the pilot injection, if so, how can you disconnected it just so im sure its that and the injector or anything else
04 LB7
CREW CAB 4X4
HYPERTECH PROGRAMER
17'' WHEELS ON 35'S
JJ78040 is offline
post #4 of 8 (permalink) Old 06-10-2011, 08:05 AM
taylorbok's Avatar
I am not sure 100% so some one correct me if I am wrong but, pilot injecton uses the injectors in the head, it is a small squirt of fuel before the main injection starts, It's to lower cylinder pressure and help quiet the motor during ignition, you need efi live to turn it off but I dont think any one does that.
how loud is real loud? how are your balance rates?
post #5 of 8 (permalink) Old 06-10-2011, 04:08 PM Thread Starter
JJ78040's Avatar
Originally Posted by taylorbok View Post
i am not sure 100% so some one correct me if i am wrong but, pilot injecton uses the injectors in the head, it is a small squirt of fuel before the main injection starts, it's to lower cylinder pressure and help quiet the motor during ignition, you need efi live to turn it off but i dont think any one does that.
How loud is real loud? How are your balance rates?
will check balance rates this weekend, and its annoying loud....
04 LB7
CREW CAB 4X4
HYPERTECH PROGRAMER
17'' WHEELS ON 35'S
JJ78040 is offline
post #6 of 8 (permalink) Old 06-10-2011, 09:37 PM
Banned
Could have got some dirt in the other injectors causing them to lock up.
JoeSmith21 is offline
post #7 of 8 (permalink) Old 06-12-2011, 03:28 PM Thread Starter
JJ78040's Avatar
Anybody???? Haven't done the balance rate check, but this knock sounds bad and a lot of black smoke, knock and smoke not there before replacing this injector
04 LB7
CREW CAB 4X4
HYPERTECH PROGRAMER
17'' WHEELS ON 35'S
JJ78040 is offline
post #8 of 8 (permalink) Old 07-08-2011, 02:29 PM
Noisy Injector
I have a 2002 2500HD with 127K miles. One of my injectors failed completely and dumped gallons of diesel fuel into the crankcase. The dealer told me that one had failed completely and 4 others were shot too. I ordered a reman kit from Pensacola Diesels. After I spent 3 days changing the injectors, I started the truck and noticed what sounded like a rod knock. I took it to the dealer who ran a test (increasing the fuel pressure in each injector 1 at a time) and notified me that I indeed had a rod knock from #7. I changed out the rod bearing from underneath the vehicle. #7 and #8 are accessible. The old bearing was not bad, and of course this did not fix the noise. I went back to the dealer who told me the wrist pin must be bad. Right! On paper, they recommended a new engine. I found another diesel mechanic that told me the injector was not preinjecting which was making it inject like an old school diesel. I called Pensacola who promptly and without question, sent me another injector. I replaced that injector and surprise, surprise, the noise is gone! so much for needing a $10,000 engine.
It sounds like you have a bad injector.
SanDogDuramax is offline
