Change Oil Light - Chevy and GMC Duramax Diesel Forum
post #1 of 19 (permalink) Old 06-15-2011, 03:54 PM Thread Starter
Harold 66's Avatar
Red face Change Oil Light
Can someone tell me how to cancel the change oil light? all I can remember is stepping on the throttle three times.I just changed oil & filter about 200 miles ago & now the change oil light is coming on.Would be appreciated.
Harold 66 is offline
post #2 of 19 (permalink) Old 06-15-2011, 03:58 PM
Baadgoat's Avatar
Turn the key to the on position, do not start the truck step on the gas pedal three times. Then it should say on the DIC change engine oil, oil life reset.
2006 CCSB LBZ- EFI Live | Sinister EGR Delete | ADII 165 | MBRP 4" | American Force 22x12 | 33" Toyo MT | Amp Research
2007.5 CCSB LMM- SOLD
2006 CCSB LBZ- SOLD
2005 CCSB LLY- SOLD
2003 CCSB LB7- SOLD
Baadgoat is offline
post #3 of 19 (permalink) Old 06-15-2011, 04:16 PM Thread Starter
Harold 66's Avatar
Oil Light
Thankyou
post #4 of 19 (permalink) Old 06-15-2011, 04:54 PM Thread Starter
Harold 66's Avatar
Tryed the step on peddle 3 times,did,nt work,this is a 01 D/A 3500,I turned the key on without starting it,then stepped on the throttle 3 times leaving about 2 sec. between stepping on it.Turned the key off,then started it up,light still came on,change oil,what am I missing here?
post #5 of 19 (permalink) Old 06-15-2011, 04:56 PM
daword2011's Avatar
I always learned 5 times... but don't pause too much just floor it 5 times with a second or so between and turn it back off, wait a min and start her up
-Austin- Fightin' Texas Aggie
2001 LB7 2500HD CC/SB 2WD
Slower then a three wheeled Prius running on bio-diesel .
546hp & 1025 ft/lbs at Lone Star Dyno, Spring Branch Tx.
Best Run: 13.23 @101 with 1.90 60
daword2011 is offline
post #6 of 19 (permalink) Old 06-15-2011, 05:10 PM Thread Starter
Harold 66's Avatar
Ill try the 5 times,the 3 times did'nt work.If this dos'nt work Ill get the wires cutter out.LOL
post #7 of 19 (permalink) Old 06-15-2011, 05:19 PM Thread Starter
Harold 66's Avatar
Yup 5 is the lucky number,not 3,ThanksGot it, all out now.
post #8 of 19 (permalink) Old 06-15-2011, 08:44 PM
daword2011's Avatar
ok good haha cuz i remember doing 3 and it not working!
post #9 of 19 (permalink) Old 06-15-2011, 09:22 PM
roxyfever's Avatar
yeah on mine i turn key on then wait for the dinging to stopo then go three times
2003 ford explorer v6
Wifes ride/2009 6.4 F350 SRW CCLB 4x4 135k
roxyfever is offline
post #10 of 19 (permalink) Old 06-16-2011, 11:35 AM
Baadgoat's Avatar
Your all doing something wrong, I do this everyday for a living... Its 3 time within 5 sec. Check your owners manuals.
Straight from GM Service Info.
Service Information
Chevrolet Chevy K Silverado - 4WD | Sierra, Silverado VIN C/K Service Manual | Engine | Engine Controls - 6.6L | Repair Instructions | Document ID: 737242
GM Oil Life System Resetting
The engine oil life monitor will indicate when to change the engine oil - usually between 5 000 km (3,000 miles) and 16 000 km (10,000 miles) since the last oil change. Under severe conditions, the CHANGE OIL SOON light may be displayed before 5 000 km (3,000 miles). The vehicle must not be driven more than 16 000 km (10,000 miles) or 12 months without an oil change.
Reset the oil life monitor when the oil has been changed, use the following procedure.
•Turn the ignition key to the RUN position.
•Fully push and release the accelerator pedal 3 times within 5 seconds.
•If the Change Oil Soon light flashes, the system is resetting.
•Start the vehicle.
•The oil life will change to 100%.
•If the Change Oil Soon light comes back on, the system has not reset.
Repeat the procedure.
Thank you...
2006 CCSB LBZ- SOLD
2005 CCSB LLY- SOLD
2003 CCSB LB7- SOLD
Baadgoat is offline
