How many miles on your odometer? - Page 10 - Chevy and GMC Duramax Diesel Forum
Old 12-01-2012, 09:00 AM   eBay Motors  #91 (permalink)
Blackmamba 02's Avatar
216k, 2 sets of injectors, hydroboost, waterpump, and a new front end. Love this truck.
2002 LB7 4X4 CC/SB
4.5 BDS lift, 35x12.5x20 Toyo Mt, BMF Novakanes
5% tint, Ranch Hand bumper
color matched bumpers
Kleinn train horns
Viper alarm/remote start
AFE intake, plugged resonator
Dumped straight pipe w/6'' RBP tip
PPE Standard tuner,PPE boost valve
Nicktane Cat Adapter, MA pump rub fix
Blackmamba 02 is offline   Reply With Quote
Old 12-01-2012, 08:33 PM   eBay Motors  #92 (permalink)
ctsrrrules's Avatar
356,700 miles burning oil a little but it still hauls a**. Replaced injectors at 352,000
Caden- 25
2003 Chevrolet Silverado 2500HD- 362,000~ Miles
EFI Live by Caleb @ Blackout Performance
Edge Insight CTS w/ non expandable EGT probe, Airdog 2 DF-165, Banks Ram Air, Profab Intake Horn, PPE Boost Valve, MBRP Downpipe, Diamond Eye 5" Turbo Back no muffler
2008 Harley Davidson Softail Night Train- Screaming Eagle Intake, Vance & Hines black short shots, Arlen Ness 3" forward control extensions, Fat spoke wheels
ctsrrrules is offline   Reply With Quote
Old 12-02-2012, 08:28 AM   eBay Motors  #93 (permalink)
2Lane Racer's Avatar
169,XXX now. I bought it w 167,000 in early September '12 from the second owner who had it for 98,xxx. Needs injectors again, (first set was done by GM), water pump shows signs of leaking, hydroboost unit leaks, and now has a pump rub hole. Previous owner just drove it and never serviced anything but the oil and fuel filters, I think. :/
I have changed all the fluids. The trans fluid came out clear thankfully and everything works well and it runs like a TOP. But its smokes like a train at the red lights. I paid $5700 and put another $1000 in it with front end rebuild including 1 hub and all the fluid changes. I'm figuring another $3500-4000 to get it where it needs to be. I just use it for a second vehicle but I want it to be able to trust it to go anywhere, anytime.
Lane
92 3500 DRW single cab, NV4500, 3.73, 190,000 on truck, 15,000 on rebuild. Diamond Eye 3" to 4" straight pipe.
02 2500HD Allison CC LWB 4x4 171,000
Just installed its 3rd set of injectors, efi live with dsp5 switch, much more to be done...
09 Silverado CC gasser 132,000
SOLD
2Lane Racer is offline   Reply With Quote
Old 12-02-2012, 09:14 AM   eBay Motors  #94 (permalink)
boostnlb7's Avatar
truck and tranny have 264,000...motor has 18,000, i bought the truck 4 years ago and until i spun a couple main bearings it was a problem free truck, now just upgrading more..hehe
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is online now   Reply With Quote
Old 12-02-2012, 10:09 AM   eBay Motors  #95 (permalink)
05 3500 2wd's Avatar
39413, Just about to get it broke in.
Clifford is a 2005 GMC Loaded SLT 2wd with; true cold air intake mods, ported LBZ turbo inlet mouthpiece, AFE Inter cooler pipe, Diamond Eye down pipe, BD drivers side manifold, Silverline 4" S/S exhaust, EGR Blocked, EFI Live DSP5 By Idaho Rob, Bully Dog pillar mounted outlook monitor, V2 radiator, thermostst controlled oil cooler, 19.5" aluminum wheels with factory lug covers, Goodyear G647RSS 225/70/19.5, BF Xenon 6000k Headlights Low & Hi, Air lift Remote control 5000# air bag system, Rear mounted under the bumper halogen lights, EZ down Tailgate assist, Put co S/S mud flaps, compete interior wood dash kit, Dual Liner 3 piece bed liner with rubber floor mat, Roll-N-Lock tonne cover with tail gate lock, and AVS in channel vent visors.
05 3500 2wd is offline   Reply With Quote
Old 12-03-2012, 06:57 PM   eBay Motors  #96 (permalink)
boostnlb7's Avatar
LOL break in isnt for another 100k bud.. wish mine had that low of miles
Old 12-03-2012, 07:31 PM   eBay Motors  #97 (permalink)
jacked-up_redneck's Avatar
Don't we all. Got 245k on mine, injectors at 196k, belt tensioner and idlers at 210k. transfer case at 225k.
DD: 2002 gmc lb7 ccsb, 6" rcd lift, rolling dunlop mts, 5" mbrp turbo back, efi live by idaho rob, banks cold air, Airdog 150, Ppe oil centrifuge, Udp fuel filter adapter with 1 micron filter, Ppe boost valve, Profab dp, manifolds/up pipes, and intake horn, Custom trac bars, bt diesel works tapshift, batmowheel
jacked-up_redneck is offline   Reply With Quote
Old 12-03-2012, 07:47 PM   eBay Motors  #98 (permalink)
boostnlb7's Avatar
at least were driving chevy's fellas, could be a dodge or something.. ill fix my truck ten times over before i buy something like that..LOL
Old 12-03-2012, 07:50 PM   eBay Motors  #99 (permalink)
roxyfever's Avatar
Are all these miles stock or have they been modified miles
2007 CCSB GMC 4X4 LT
PERFORMANCE-5inch flo pro, egr block plate, PCV reroute, EFI AUTOCAL from ATP
INTERIOR-Autometer cobalt boost, EGT, Trans, Cobra 29 ltd
EXTERIOR-285/55/20 camo rockstars, ready lift leveling kit with one inch block, step bars, headache rack
422hp/760TQ may 26 2012
roxyfever is offline   Reply With Quote
Old 12-03-2012, 08:01 PM   eBay Motors  #100 (permalink)
boostnlb7's Avatar
whats in my sig has been on mine for almost 4 years
