Old 10-23-2008, 09:56 PM   eBay Motors   #21 (permalink)
The Stealth
duramax-rockstars's Avatar
my friends 03 has an edge and everything else is completly stock..it dumps the fattest cloud ive like ever seen haha.. i have noo clue why it blows so much.. he can cloud a whole intersection
hey my name is coady! im 18 years old, i drive an 04 blacked out duramax with a 6 inch lift 35 inch a/ts, 20 inch kmc rockstars, and 33x15.50 super swampers, with 12's. Quadzilla Stealth 2 at 135HP, Train horns, 5/8 lines,limo tint all the way around, 35% tint on windshield, 8 inch brow. 7 inch black stack. afe stage 2 intake. painted grill and bumpers.halo projector black headlights with green L.E.D's,10000k HID's. blacked tail lights. JVS EXAD deck 3 1/2 inch screen. two 15 inch subs,power capasitor, 2000 watt amp. line-x bed liner. http://www.discounttiredirect.com
duramax-rockstars is offline   Reply With Quote
Old 11-01-2008, 12:12 PM   eBay Motors   #22 (permalink)
Originally Posted by 03DuramaxLB7 View Post
my tune set in finally and i only get smoke thru 1st and 2nd on level 5 with my xcelerator. but not in 3rd thru 5th. i need the ppe electric fuel pump
Features:
160 Gph fuel flow
Internally regulated fuel pressure
Fully adjustable fuel pressure from 0 to 15 PSI (factory preset at 12 PSI)
Compatible with bio, low and ultra low sulfur diesel fuels
Application: 2001-2008 Duramax, Power Stroke and Cummins diesel engines
Product Description:
The Xcelerator series of hand-held programmers can give you more fuel to your engine but your stock fuel system might not be able to keep up. Low fuel pressure to your vehicle's CP3 pump can result in poor performance or injection pump damage.
The electric fuel pump was specifically designed for today's diesel engines and provides 160 gallons of fuel per hour (Gph) of fuel flow, internal regulation of fuel pressure and fully adjustable fuel pressure from 0 to 15 PSI (factory preset at 12 PSI). This pump is compatible with bio, low sulfur and ultra low sulfur diesel fuels and is highly recommended if you have an Xcelerator or Dual Fueler CP3 kit.
That PPE will be LOUD. If you don't want to hear it check out TTS. It it flow thru, virtually silent, and will support 600hp at the tires
04 ec sb lb7 -Full Corsa Exhaust -EFI Live & DSP5 by Nick -Outlook -PPE Boost Valve - Airaid drop in -air box mod -puto nerf bars-transfer flow fast fill kit-TTS billet pick up- TTS Dual Lift Pumps
dt2448 is offline   Reply With Quote
