Old 10-16-2008, 01:05 PM   eBay Motors  #1 (permalink)
idle control
just wondering if any of you guy ever thought of putting a idle control in for when the truck is idleing for long peirod of times to build oil pressure.
2002 CHEVY 2500HD, PPE BOOST VALVE, POWER FLOW INTAKE, PPE STANDARD XCELERATOR, IDEL CONTROL, GLOW SHIFT BOOST GAUGE AND EGT GAUGE, 285/75-R16 TIRES, MUFFLER DELETE. DINKERS
leterpour is offline   Reply With Quote
Old 10-16-2008, 03:27 PM   eBay Motors  #2 (permalink)
another red name!!!
ob_1jr's Avatar
you talking about the elevated idle activated by cruise control??? yes I have done it and it works great...I bought a kit from Eric Merchant (see signature) LB7 High Idle Kit and the instructions to install it are here: Fast Idle Installation Instructions for LB7 Duramax
let me know if u have any questions on installation. You can do this mod for about $5 (pins being the most expensive part of it)....but to have everything you need for $12..not too bad.
Racor 2 Micron pre-OEM with heater & water sep.
Old 10-17-2008, 06:48 AM   eBay Motors  #3 (permalink)
high idle
so it works good for you? i just heard that is better for the engine to run a little high rpm while idleing. good for in the winter also. so hard do you think it is to install and how long does it take?
Old 10-17-2008, 07:05 AM   eBay Motors  #4 (permalink)
timespentsearching's Avatar
bd makes a 3 setting high idle kit/switch, its 25 bucks. im going get one here before winter and another for my dad for an yearly christmas present
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders, 255/85R16 BFG KM2
Screamin Diesel Performance
timespentsearching is offline   Reply With Quote
Old 10-17-2008, 07:32 AM   eBay Motors  #5 (permalink)
another red name!!!
ob_1jr's Avatar
it works pretty good. It took me an hour because I was just taking my time and messed around trying to get the wire through the firewall to the brake pedal wire (green/white). I have it set up to work with my remote start...I use the trunk button on my remote activate the high idle.
Old 11-02-2008, 05:59 AM   eBay Motors  #6 (permalink)
how did you get it to work from your remote starter??
2003 GMC SIERRA 2500HD Crew
6.6 Dura7
S&B Cold Air Intake, AFE Stainless 4" Exhaust, Edge Juice w/Attitude
305/70/16's coming off and switching to 285/70/17 Goodyear SilentArmors on 17" Gear Alloy Double Pump Wheels
oneraddoo is offline   Reply With Quote
Old 11-02-2008, 06:10 PM   eBay Motors  #7 (permalink)
chevymakesitizuzushakesit's Avatar
your trucks dont come with the elevated idle mine can do it from the steering wheel
05' CCSB 4x4 DMAX/Allison is junk
# 15 top 25 slowest stock duramax
wooster diesel performance!
chevymakesitizuzushakesit is offline   Reply With Quote
Old 11-02-2008, 08:04 PM   eBay Motors  #8 (permalink)
Durallymax's Avatar
all LLYs and newer have it, the LB7s dont.
I am lazy and havent installed one yet so I use my laptop to riase the idle.
The pins are a rip off.
Install is easy just make usre you disconnect the batteries.
The Pins can also be a pain to get seated in the harness just take your time.
The "Last Minute Puller"
'03 GMC 2500HD LB7/Allison EC/SB 4x4
Suncoast, EFI Live, S400, Studs, Stock Motor
Badger Truck Pullers Association Member
Thanks to all of my sponsors
Videos Here
And Here
Vinny
Durallymax is online now   Reply With Quote
