LB7 Diablo Predator? - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 10-28-2011, 06:01 PM Thread Starter
I have a 03 lb7 and am looking at running the diablo predator on 85hp tune daily. I was wondering if it would put any added stress on my stock injectors? I know they are known for going bad and I don't want to speed the process of failer. I would appreciate any input. Thanks in adance.
03 LB7 leveled,ppe boost valve,tuned ecm by duramax tuner with dsp5,k&n intake system
285/75r16 duratracs
kooz728 is offline
post #2 of 12 (permalink) Old 10-28-2011, 06:05 PM
SKY
SKY's Avatar
efi and get airdog 2 165gph
2007 GMC Sierra LBZ 4x4
4" mbrp, PCV reroute, Egr delete, Fuel rail plug, S&b Intake, Autometer Boost/Pyro, Efi Live by Lee Allgood
SKY is offline
post #3 of 12 (permalink) Old 10-29-2011, 03:11 AM
Your injectors will fail one day.......can't imagine it would make that happen much faster.....
03 2500 LS, LB7, CCLB
hardtail is offline
post #4 of 12 (permalink) Old 10-29-2011, 03:24 AM
BiloxiDmax's Avatar
Ive been running it on my lly for bout 2 years and no problems yet but im bouta change to efi live asap. I dunno if its more prone to mess up the lb7s or not but i have heard that they have always had problems wit those injectors anyways. IMO knowing what i know now if i could go back i would just save a little more money and get a efi live tuned ecm from rob. Its a whole lot better bang for the buck!
PS Also i have had problems with my DS predator defueling at high speeds even with a lift pump but other than that i guess i can say ive got my 250 bucks out of it for a beginner tuner
[SIGP[/SIGPIC]
Chase
BLACK 2005 Chevy 2500 CC 4x4 LT, Black 20x10 USA WARHAWKS on 305/50 NITTO 420S, Black Javalina front bumper w/halo projector fog lights, Murdered!
4" dual exhaust, intake, traction bars, LBZ m/p, egr blocked, PPE FPRV shim kit, PPE lift pump, PPE Stage V with M.L., ARP studs, CP3 by TC Diesel, Extrude Honed 30% nozzles, DSP5 by Rob
BiloxiDmax is offline
post #5 of 12 (permalink) Old 10-29-2011, 04:40 AM
Slave to the Interwebs
Johnasara's Avatar
I ran the predator on my LBZ for about a year. It worked well on the 85 tune. The 120 would defuel pretty good. I do not think it will speed up the injector failure. I would look into running a better filtration system and a fuel additive. It will help the injectors live a little longer. I know guys around here who have 250k+ miles with no issues.
Johnasara is offline
post #6 of 12 (permalink) Old 10-29-2011, 12:31 PM Thread Starter
Thank you for all the input. I would be going with efi live but cant do it at the moment.
285/75r16 duratracs
kooz728 is offline
post #7 of 12 (permalink) Old 10-29-2011, 01:06 PM
Northwest Coal Roller's Avatar
Well technically any tune your running has the potential to shorten your injectors life. This is simply becuase you have the opportunity to run more fuel though it. Now will it really make a difference. Probably now... I would seriously look into the AD 165 and nicktane setup... JMO
Sent from my phone
2003 LB7 ECSB:
SDP S467.7, Kryptonite everything upfront, EFIlive from Kory, 40% overs, DSP through Edge CTS, Alligator Stage V Trans, BT Lockup Box, PPE Tranny cooler, AD 165, Cognito Traction Bars, 5" FloPro straight pipe, 20x12 -44 Black Rhino Glamis wheels, 35x12.5 Toyo AT2, Line-X Rockers
Daily Driver: 2014 Cruze TDI, cold air intake (best mod ever), 5% all the way around
PhotoBucket: http://s793.photobucket.com/user/mic...bock1/library/
Northwest Coal Roller is offline
post #8 of 12 (permalink) Old 10-29-2011, 10:40 PM
danzick's Avatar
had a predator on 85 for like 6 months. loved the tune, worked awesome, only limped the tranny once on it, and i was being very hard on it that day, my injectors are horrible right now, cant say if its from the predator or not.
2004 LB7 ECLB
s475/stock
built trans
danzick is offline
post #9 of 12 (permalink) Old 10-30-2011, 01:40 PM
SKY
SKY's Avatar
i have ppe 2 hot and it runs good. if you want smoke and high egts get diablo but overal performance wise efi and ppe are way to go. mines a 2wd and on 3 i get 22-23 highway
SKY is offline
post #10 of 12 (permalink) Old 10-30-2011, 02:41 PM
danzick's Avatar
smoke on 120, yes. egts? no. my dd efi tune has way higher egts than my diablo did. i pulled boats and 25 ft goose neck trailers all the time on the 85 tune and rarely saw over 1200 with the cruse on 75 going up hills. obviously the trailer wasnt fully loaded, but i never had any trouble with egts.
2004 LB7 ECLB
s475/stock
built trans
danzick is offline
