Power of a lb7 please need advice - Chevy and GMC Duramax Diesel Forum
Old 11-09-2012, 09:42 PM   eBay Motors  #1 (permalink)
Hey guys I got a few questions I have a lb7 with about 120 thousand on it mods are built drivetrain built trans lift pump intake and exhaust I'm wondering if a 71mm turbo would be good for it I'm running the 500hp efi live I'm also getting duel fuelers with this turbo just wondering what I'll all need with my stock internals thanks guys
04 lb7 EFI live 500hp Tune EDGE CTS ppe 160 lift pump ppe stage 5 trans AFE stg 2 Cold air 7 inch Fts spindle kit 60'' trac bars 20inch Fuel octanes , 4 to 7 inch dual tips ... shes a work in progress!!
duramaxDEEJ is offline   Reply With Quote
Old 11-10-2012, 07:47 AM   eBay Motors  #2 (permalink)
Anyone gonna help
Old 11-10-2012, 08:04 AM   eBay Motors  #3 (permalink)
mike diesel's Avatar
Duel fuelers on a stock bottom end is a bad idea and a waste of money. Your stock cp3 has more than enough potential alone to ruin a stock motor. You could run the 71mm turbo with some 40% injectors and stock cp3 and have a pretty reliable setup.
Im assuming its an aurora 5000 turbo?? If so, you may want to look into a different turbo, those can be pretty laggy unless you throw tons of fuel at them. I bet you would have better luck with an s472.
05 lly
EFI Live
Built Trans
BT Lockup Box
GDS Billet 72vgt
Supporting Mods
mike diesel is online now   Reply With Quote
Old 11-10-2012, 09:49 AM   eBay Motors  #4 (permalink)
I figured out a 71 mm won't work for my lb7 because its Vgt so I'm getting a s366 for my lb7 I already bought the combo but if I don't need it I don't so keep posts coming I love learning
Old 11-10-2012, 10:01 AM   eBay Motors  #5 (permalink)
S366 and some 40% nozzles and a stock cp3 would be an awesome combo. That will do 600+ horse. 600 horse is pushin into the limits of a stock bottom end.
05 lly
EFI Live
Built Trans
BT Lockup Box
GDS Billet 72vgt
Supporting Mods
Old 11-10-2012, 10:05 AM   eBay Motors  #6 (permalink)
Yeah I'd get some 40% nozzles and ditch the dual fuelers. There's really no need for them.
2006 CCSB
Big Dipper - SkyJacker - EFI Live - Mickey Thompson - HID - Amsoil. http://www.trollperformance.com/
SwitchBack is offline   Reply With Quote
Old 11-10-2012, 10:08 AM   eBay Motors  #7 (permalink)
What if I didn't get injectors ? I feel like right now I have more then enough fuel I wanna burn it up would a 66 limited to let's say 45 boost obviously with head studs be a good way to go about it ?
Old 11-10-2012, 10:27 AM   eBay Motors  #8 (permalink)
SickLB7Crenshaw's Avatar
30% over inj, s366 should be a great setup. Question is whos doing your tuning?
05' LLY 12.41 @109.9
Blake
SDP Twinz, 40% overs, EFILive, Stage V trans, BT lock up box
4'' Exhaust, Airdog, Traction Bars, Built Front End,
Big Thanks to Dustin, Idaho Rob, and Scott
01' LB7 13.5@97
EFILive, Grade C HG, ARP studs,
4 in duals, S@B intake, Airdog, PPE boost valve, BT lock up box on stock trans
SickLB7Crenshaw is online now   Reply With Quote
Old 11-10-2012, 10:32 AM   eBay Motors  #9 (permalink)
Well I have showemupmotorsports out of Milaca man doing them but there getting the base tunes from fleece the only thing we have done different is adding values for trans pressure for the cold weather
Old 11-10-2012, 10:36 AM   eBay Motors  #10 (permalink)
hmm...
Blake
01' LB7 13.5@97
