Turbo leaking oil after batmowheel install - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 11-12-2012, 01:10 PM Thread Starter
This weekend I installed a batmowheel while I had my cp3 off and after all is said and done now have a oil leak between the turbo and exhaust housing where the v band clamp is located it move slightly out when trying to get it off but didn't come all the way out now its leaking oil pls help idk what I can do to fix this
2003 duramax-efi live (tuned by me),100hp lightening nozzles, fass, cold air, 5in farmboy diesel exhaust, mild built tranny(trans go deepdish pan and clutches),with 1056 suncoast
1994 6.5- cold air intake,4in exhaust, 3 in down pipe, #9 ssd resistor, 80hp ssd chip, marine injectors, south bend clutch, solid mass flywheel
03dirtylb7 is offline
post #2 of 8 (permalink) Old 11-12-2012, 01:43 PM
mackyoudip's Avatar
you may have had a bad turbo to begin with..check for shaft play first, it may be a seal that was either bad or you caused to go bad.
Mack: 2004 lb7
1960 f100 Cummapart conversion
Ex's:2006 LBZ ppe tuned
2007.5 LMM s366. 12.4@109
mackyoudip is offline
post #3 of 8 (permalink) Old 11-13-2012, 07:37 AM Thread Starter
Well took a real close look after I posted and turns out to be leaking a the oil drain at least so I think now is their anyway to tighten the bolts with out pulling everything apart
post #4 of 8 (permalink) Old 11-13-2012, 04:56 PM
i had the same problem. did you put new gaskets on the oil drain?
2005 lly cc/sb efi dsp5 w/ max effort, 4inch srt8 piped, 3 inch down pipe, ppe race fuel valve, banks hot side boost tube, ppe lift pump, egr blocked w/ cooler delete, pcv reroute, lbz m/p, batmowheel, infinity kappa doors and tweets on 600w, alpine type x on 3000w hifonics, 180 amp dc power alt., bfg altrn. Very soon to be built stock trans.
embs2001 is offline
post #5 of 8 (permalink) Old 11-13-2012, 05:38 PM
Administrator
jc1843's Avatar
Moved to LB7 performance-- not a 911 problem.
jc1843 is offline
post #6 of 8 (permalink) Old 11-14-2012, 09:14 PM
does it make that big of a diffrence in it and how does it sound compaired to this cause im contemplating just spending the money and getting this
lb7Dstar is offline
post #7 of 8 (permalink) Old 11-14-2012, 09:26 PM
lb7Dstar is offline
post #8 of 8 (permalink) Old 11-15-2012, 07:08 PM Thread Starter
No I didn't change the oil drain gasket didn't have turbo off just took housing off..ended up tearing it down again and oil drain gasket was screwed of put new one on now it's got a small leak somewhere think I'm giving up and taking it to the shop......as of sound it is As loud or louder than my friend super b special on His Cummins
