Downpipe install - Chevy and GMC Duramax Diesel Forum
Old 11-12-2012, 06:06 PM   eBay Motors  #1 (permalink)
Recker's Avatar
Downpipe install
Thinking about getting this downpipe
2001 2004 GM Cheverolet Duramax Diesel Turbo Direct Downpipe Stainless LB7 | eBay
I believe its made by pypes pn#DTD0104. Wondering if anyone's used this?
Also should i get a new flange gasket for the turbo or does everyone reuse the one on it?
Any other tips are also greatly appreciated!!!
2003 Medium Green Metallic CC/SB LB7 Duramax
EFI Live With DSP5 | Autometer EGT, Fuel, Boost | MBRP 4" Straight Pipe Exhaust
PPE Boost Valve | Fass 150 Titanium | Bills Custom AEM Intake | ProEFX Cowl Hood
Debadged | Zone Keys & Blocks | High Idle Mod | High's/Low's/Fog's All On Mod | DDM 5000k HID's
Tinted Lights And Windows | Black And Machined 17" Eagle 197's On 285/70/17 AT3s
Rough Country Sleeves | DHD Steering Brace | LML Exhaust Manifold | Diamond Eye Downpipe
Wishing For A Built Trans!
It's Safe To Say I'm A Little Addicted...
Recker is offline   Reply With Quote
Old 11-13-2012, 06:40 AM   eBay Motors  #2 (permalink)
Mr. Neptune's Avatar
If you are doing it youirself you may want to read some of the other posts on the subject first. I have a aftermarket downpipe on my truck and the only real difference I seen with it was the exhaust tone. But if you have plenty of time to get it done and up for the challange, go for it.
2004 LB7 CCSB Arrival Blue
6" lift, 35's
FASS Titanium 150
MBRP 4" stright exhaust + downpipe
Bill's Custom 4" Horn and Intake
Edge CTS used for gages
Nictane Adaptor
Stage V Transmission
EFI Tunes by Wade
Mr. Neptune is offline   Reply With Quote
Old 11-13-2012, 04:10 PM   eBay Motors  #3 (permalink)
Recker's Avatar
Did you reuse the gasket? I cant find an install post that says anything about it.
Old 11-13-2012, 04:23 PM   eBay Motors  #4 (permalink)
Thebiggids's Avatar
Magna flow makes one cheaper than that and its wrapped.
My mbrp came with a gasket, id expect most kits too. But if the gasket looks ok im sure you can re use it.
Hope youre ready for a PITA job if the bolts dont break loose easily
Gideon
01 LB7 EC/SB Ally 4x4 shop ornament
DD: 1990 4runner completely stock 4x4 3.slow
Big Thanks To Adrenaline Truck Performance, Alligator Diesel Performance, and Socal Diesel
Thebiggids is offline   Reply With Quote
Old 11-13-2012, 04:29 PM   eBay Motors  #5 (permalink)
bigjohn's Avatar
Magnaflow just came out with that right.
2006 2500 HD SLT ECLB, LBZ, Bilstein shocks,Banks 4inch exhaust, Alligator Adp Cat filter. And S&B air intake good to be driving a diesel again.
2002 Chevy silverado 2500 HD, LB7, traded it on a gasser and then traded it in for LBZ.
bigjohn is offline   Reply With Quote
Old 11-13-2012, 04:44 PM   eBay Motors  #6 (permalink)
biketopia's Avatar
I reused the gasket on mine. Just soak the bolts with a good penatrent, PB blaster, Aerokroil, for a couple of days before hand and take your time, pull the front pipe out of the exhaust and I also removed the bolts for the trans mount and jacked up the trans and engine to get the old one out. Took a little persuading to get the new one in. I noticed lower EGT's, deeper tone, and quicker cool down.
2003 2500HD LT CCLB, 4" MBRP, Diamond Eye Down Pipe, Ported Intake Horn, S&B Intake, PPE Boost Valve, ADII, Nicktane CAT Adapter, Edge CTS, Cognito UCA, Rare Parts Tie Rods, Bilsteins, Gear Alloy wheels, Hankook RF10 285's, PPE Level 2, All on Mod, DDM 5k Low's & 4300 Fogs, air horn, on board air
http://www.trollperformance.com/ You know you want too
biketopia is offline   Reply With Quote
Old 11-13-2012, 04:51 PM   eBay Motors  #7 (permalink)
Thebiggids's Avatar
I knnow alligator advertised them. 130-135 IIRC. Dirt cheap...I paid 270 for mine. And magnaflow makes quality stuff so id trust it way more than an ebay one...plus supporting a site vender
Gideon
Old 11-13-2012, 06:26 PM   eBay Motors  #8 (permalink)
Recker's Avatar
magnaflow makes one for less than $150?
Old 11-13-2012, 06:28 PM   eBay Motors  #9 (permalink)
Some Newfie with a dmax
Brennan's Avatar
Pro fab do
06 lly,
Black,
Levelled,
Efi by rob,
5"
Etc.
Brennan is offline   Reply With Quote
Old 11-13-2012, 06:32 PM   eBay Motors  #10 (permalink)
Recker's Avatar
Originally Posted by Brennan View Post
Pro fab do
do you like yours?
