Leveling Kit ?'s - Chevy and GMC Duramax Diesel Forum
Old 11-13-2012, 07:50 PM   eBay Motors  #1 (permalink)
Leveling Kit ?'s
I've decided I am going to order 3" keys from FatBob's Garage. I am also getting new shocks all the way around. I am going to crank the keys a little bit past 3" in order to clear 305/70R18 Dick Cepek FC ll's. The first question I have is what size block to get for the rear so the truck sits level and not raked. Second question is what offset and backspacing do I need to get when i get my new rims.
2004 CCLB LB7
3" Leveling Keys with 2" Blocks in the Rear
ProComp RS 9000 Shocks
18" Black XD Crank with 305/70R18 Dick Cepek FC II
EFI Live Idaho Rob
DSP through Edge Insight
Profab Downpipe
4" MBRP straight pipe w/ 5" tip
Soon to Come:
30% or 40% Overs
AirDog II 165
tosterland is offline   Reply With Quote
Old 11-13-2012, 07:57 PM   eBay Motors  #2 (permalink)
Administrator
ob_1jr's Avatar
you might want to think about cognito UCAs too unless you like replacing ball joints often.. If you are going with 3" up front, you could probably use a 1.5" block in the rear and it should be nearly level. I didnt crank my truck up much with the stock keys (maybe 10-12 turns of the bolts). I think it brought it up about 2" in the front...I put the 1.5" blocks in the rear to keep the factory rake.
I dont know about the rim though.
SOLD
305/70-16 BFG T/A KOs on Eagle Alloys Series 187
Clifford remote start. High Idle, Bilstein 5100s, 1.5" lift blocks
CAT fuel filter w/ nicktane adapter
Magnum Force Stage 2 intake with AMSOIL filter
Racor 2 Micron pre-OEM with heater & water sep
Lightforce 140s from Madjackracing
http://WWW.ATPTRUCKS.COM/
Old 11-13-2012, 08:33 PM   eBay Motors  #3 (permalink)
I have considered Cogntio UCA's but think I am going to try it without them first just to see how it rides
2004 CCLB LB7
EFI Live Idaho Rob
Profab Downpipe
Soon to Come:
30% or 40% Overs
AirDog II 165
