Need help with injectors. - Chevy and GMC Duramax Diesel Forum
Old 12-25-2012, 12:11 PM   eBay Motors  #1 (permalink)
bags's Avatar
So after some trouble shooting it is looking like i need another set of injectors. just replaced them 35k ago. when the truck is warm it cranks for a while be fore firing. builds rail pressure afterwards and drives good, no white smoke, no fuel in oil. i will be checking balance rates tomorrow. but i think i have a stuck injector.
I would like to change them out for some 30 overs. Was wondering if anyone had a good deal or good really help me out with these. was told these would probably last longer. thanks
PPE parts, built trans, EFI, water meth, some gauges.
558 RWHP....Stock Ally.
bags is offline   Reply With Quote
Old 12-25-2012, 12:16 PM   eBay Motors  #2 (permalink)
Thebiggids's Avatar
Can I ask where you got the injectors from?
Gideon
01 LB7 EC/SB Ally 4x4 shop ornament
DD: 1990 4runner completely stock 4x4 3.slow
Big Thanks To Adrenaline Truck Performance, Alligator Diesel Performance, and Socal Diesel
Thebiggids is online now   Reply With Quote
Old 12-25-2012, 02:19 PM   eBay Motors  #3 (permalink)
bags's Avatar
a guy on ebay. said they were bosch remans. blackregal1000. sells others as well from time to time.
Old 12-25-2012, 02:53 PM   eBay Motors  #4 (permalink)
Thebiggids's Avatar
Yeahhh I wouldnt buy injectors off ebay. JMO.
Id buy injectors from a well known shop that bench test and calibrate the injectors at idle, part throttle, and WOT. Shops like Merchant automotive and Socal diesel. LDS also sells a lot of injectors but im not sure if he has the equipment to bench test and hone them youd have to call but he has a lot of good reviews.
In theory they could last longer. Because the bigger injector is open for a shorter period of time since it can injector more fuel faster, so yes it could perhaps make them last longer. But you would have to not turn it up and make more power because the bigger sticks. As long as Pulse width is lower...it could poissbly make them last longer
Gideon
Old 12-25-2012, 03:23 PM   eBay Motors  #5 (permalink)
bags's Avatar
i found some injectors for injectorsdirect. heard alot of good things about them. he has a brand new set of bosch's that are 40% for 2400. I think i might go with them. they are a little bigger than i want but the price is great for brand new injectors
Old 12-25-2012, 05:13 PM   eBay Motors  #6 (permalink)
boostnlb7's Avatar
just installed my 45% injectors from LDS for cheaper LOL
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is offline   Reply With Quote
Old 12-25-2012, 05:25 PM   eBay Motors  #7 (permalink)
Offical LB7 "Tech"
01 D_Max's Avatar
Yeah man, seriously talk to Brent at Lincoln Diesel! He has a great product and prices, But the best part is their Customer Service.
-Aaron-
2001 GMC Sierra 2500HD, Limited Edition, CC,SB
EGT's Never higher than 1150*
Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, BATMO, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler- Wastegate, FASS 150, LBZ FPR, Shimmed FPRV, Built Trans, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler
Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires,
MANY More extras inside...
01 D_Max is offline   Reply With Quote
Old 12-25-2012, 05:30 PM   eBay Motors  #8 (permalink)
boostnlb7's Avatar
second that, i can honestly say i have ''never ever'' been to any store/shop with the customer service and help that brent has given me.. he is quick on responding, helpful.. great on every aspect........ hope u read this brent
Old 12-25-2012, 06:30 PM   eBay Motors  #9 (permalink)
bags's Avatar
I will give him a call tomorrow.
Old 12-25-2012, 06:41 PM   eBay Motors  #10 (permalink)
boostnlb7's Avatar
i dont think u will regret it.. put in the good word from boostnlb7 if ya talk to him
