Ticket - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 15 (permalink) Old 12-26-2012, 01:14 PM
BorderlineReckless's Avatar
Originally Posted by justavillain View Post
That is a weird thing to use as the base line each one of our fire engines have different ratings. Our pickups (same as an ambulance just no mod) have different ratings the command truck is running 2 100watt speakers. But most ambulances run a single 100 or 150 watt speaker. While most police cars run 2 150s around here in MI
I know up here on orv trails and the dunes they have a flat 91 or 93 dcbl rating max and my yfz is below that and way louder than my lml now maybe matted under an overpass ill get to loud
Sent from my Galaxy Nexus using AutoGuide.Com Free App
my buddys straight piped lly passed the random decibel test at silver no problem
-Trent-
2008 LMM 2500HD, MA-700, MBRP 4'', K&N cold air intake, EFI Live from Diesel Addiction, edge insight, PPE lift pump, egr blocked, 33'' Goodyear duratracs on 20" XD Misfits, de-debadged,smoked tail lights and cab lights, halo headlights, black grille, leveled with keys, B&M gooseneck hitch, air ride air bags with compressor, Alligator tie rod sleeves, PPE shim kit,Rough Country 6'' Lift Powdercoated Orange, 35w 5000k HIDs highs, lows and fogs
WAITING TO BE INSTALLED - PCV reroute, Ppe rear diff cover, inline filter kit
>>>build thread<<<
BorderlineReckless is offline
post #12 of 15 (permalink) Old 12-26-2012, 01:20 PM
3521 USMC
chevylovinfordtech's Avatar
Originally Posted by Josh429er View Post
I think this is apart of them trying to constrict diesels. Did you blow black at all or revving It out. I mean It's hard to tell a diesels straight piped unless you know what your looking for. Which cops don't lol
There is a HUGE diffrence between a straight piped dmax and a dmax with a muffler, I could tell you if one has a muffler or not from 3 blocks away
-Robert-
2005 CCSB Silverado 2500 HD LLY
Performance: LBZ Mac performance intake, LBZ mouthpiece, MBRP duals, shim kit, ported fuel rail fittings, headstuds, FASS150, FASS fuel filter delete bowl, LBZ FPR, EFI live by Idaho Rob
Air Flow:finger vanes, ported turbine housing, BatMoWheel, losend unison ring, ported exhaust manifolds, gasket matched up-pipes
Exterior: Rear Reunel bumper, leveled tow mirrors, HIDs (all on mod), ADP tie-rod sleeves, green tinted headlamp housings
Interior: 2 12" memphis car audio subs, custom sealed box and 2000 watt memphis amp, LED interior, dash and door lights-green, cobalt autometer pyro and boost piller gauges
Best Time: 13.92 @ 95 mph 1.96 60 foot
Work In Progress: 1969 Chevy Nova, built turbo 350, 283ci small block est. 550hp with 7500 rpm redline, caltracs, 4.11 ford 9" rear end, dual 3"exhaust
chevylovinfordtech is offline
post #13 of 15 (permalink) Old 12-26-2012, 01:22 PM
FATBOY666's Avatar
Sounds to me like you pissed off a neighbor. For state trooper just to show up at your house and harass you is weird. But if you start the battle be prepared to get more tickets. Cause I'm sure you don't have a cat and have a programmer and such. I guy around me got pulled over in a mustang and was given about a grand worth of tickets for modified exhaust, "illegal racing components, tint, insufficient tire tread, and a couple more. All because he hassled the cop. Cop called the DOT and they red stickered it and had it towed.
06 CCSB blue granite
20x10 hostile sprocket 305 nitto 420s
5" magnaflow 3" Mbrp DP
EFI from ATP
S&B cold air
Built trans from Mike L. Goerend ML-R
PPE Gen 3 tie rods PPE deep pan Suncoast filter lock
DHD trans brace and center link brace
Air dog 150, Fass fuel filter delete
PPE race valve and ported rail fitting
Merchant PCV reroute Kennedy egr block
FATBOY666 is offline
post #14 of 15 (permalink) Old 12-26-2012, 01:47 PM
Banned
Just add a second turbo and still keep the straight pipe
Hondarider552 is offline
post #15 of 15 (permalink) Old 12-26-2012, 02:02 PM
justavillain's Avatar
Send a message via AIM to justavillain
Yeah it's actually pretty loud those sand rails with ls motors are way louder.
My 87 with a 383 true dual h-pipe passes and it's annoying some times.
The thing I know with repair and report tickets are it has a fine but only if you don't fix it and you can get it checked a few times before they make you pay.
So simply report to the station get it checked. If it passes they sign off and no harm no fowl. If its over ask for the law's (I know some have cards for the popular ones like Window tint, radio noise, exhaust, tail lights ect) number and look it up make sure the Township or village doesn't have another stricter version and get it fixed.
My township is pretty strict on noise, only 1 area worse in all of west MI (grand haven) ill get the decibel rating we need to be below I was to say it's 100. Also they may say you need a muffler and the exhaust needs to go the entire length of the truck. That's not true in many many areas I has a Michigan State Police guy tell me that and I said pull over every box truck then they dump behind the cab like mine is (the old old farm truck was a 350)
2011 Duramax LML, CCSB
H&S Mini Maxx
MBRP 4" Turbo back exhaust(DPF Delete)
aFe Intake system dry filter
Ranch Hand Legend Grille Guard
parking assist sensor delete
275/70r18 Nitto Terra Grappler
Cognito leveling keys
justavillain is offline
