dual kennedy pumps - Chevy and GMC Duramax Diesel Forum
Old 12-30-2012, 05:23 PM   eBay Motors  #1 (permalink)
Recker's Avatar
dual kennedy pumps
i have one of the kennedy pumps right now, thinking about adding two. Would it make to much pressure that it would start to surge at idle? Still kinda undecided if i need it or not because it should make around 150-160gph @ about 4 psi with just one pump. Could use anyone's input with first hand experience on these.
2003 Medium Green Metallic CC/SB LB7 Duramax
EFI Live With DSP5 | Autometer EGT, Fuel, Boost | MBRP 4" Straight Pipe Exhaust
PPE Boost Valve | Fass 150 Titanium | Bills Custom AEM Intake | ProEFX Cowl Hood
Debadged | Zone Keys & Blocks | High Idle Mod | High's/Low's/Fog's All On Mod | DDM 5000k HID's
Tinted Lights And Windows | Black And Machined 17" Eagle 197's On 285/70/17 AT3s
Rough Country Sleeves | DHD Steering Brace | LML Exhaust Manifold | Diamond Eye Downpipe
Wishing For A Built Trans!
It's Safe To Say I'm A Little Addicted...
Recker is offline   Reply With Quote
Old 12-30-2012, 05:31 PM   eBay Motors  #2 (permalink)
Banned
Pumps create flow, restriction creates pressure
I have dual Kennedy/TTS pumps and they make 8-10psi. Never surges.
Had a set on my LBZ for 4 years, and my LB7 is going on almost 2 years. Never once a problem, I love them.
Old 12-31-2012, 06:56 AM   eBay Motors  #3 (permalink)
Recker's Avatar
alright that helps me out. wasnt sure what it would do. ill order one up!
Old 12-31-2012, 10:53 AM   eBay Motors  #4 (permalink)
784x4chev's Avatar
In my opinion one pump is enough unless you are planning on a big built motor. But you could always run two and add a regulator if needed. Two is also nice for redundancy in case one goes out.
Also the statement above is incorrect. The pump creates the flow and pressure. Restriction causes a loss of pressure.
2005 Silverado 3500 SRW
4" Exhaust / 5" Tip
Predator Programmer
LBZ Turbo Inlet
784x4chev is offline   Reply With Quote
Old 12-31-2012, 11:09 AM   eBay Motors  #5 (permalink)
Banned
Actually, 2 pumps are fine for a stock engine. Ive ran them for almost 6 years.
No regulator needed as the TTS pumps are on-demand pumps.
Old 12-31-2012, 11:31 AM   eBay Motors  #6 (permalink)
Recker's Avatar
well i was thinking about just adding another since its not a ridiculous amount of money and would help over come dual filters and keep the cp3 feed with pressure at all times. i dont have a fuel pressure gauge to let me know how its working which kinda sucks for me.
Old 12-31-2012, 11:32 AM   eBay Motors  #7 (permalink)
Thebiggids's Avatar
Explain yourself o knowledgeable one!
If you have your pump running, and pinch the line...is the pressure between the pump and pinch point going to rise or lower?
Gideon
01 LB7 EC/SB Ally 4x4 shop ornament
DD: 1990 4runner completely stock 4x4 3.slow
Big Thanks To Adrenaline Truck Performance, Alligator Diesel Performance, and Socal Diesel
Thebiggids is offline   Reply With Quote
Old 12-31-2012, 11:33 AM   eBay Motors  #8 (permalink)
Banned
Glowshift has a electric fuel pressure gauge that is like 60 bucks. Can run the sending unit to the bleeder screw on the fuel filter housing and put the gauge in your pod.
Old 12-31-2012, 11:35 AM   eBay Motors  #9 (permalink)
Banned
Like I said, pumps create FLOW. RESTRICTION creates PRESSURE.
Ill put it into Laymans terms...
Turn on your garden hose at wide open, now squeeze the hose to RESTRICT the FLOW. Now you get PRESSURE.
Old 12-31-2012, 11:36 AM   eBay Motors  #10 (permalink)
TakeEm's Avatar
Pumps create flow, a restriction creates pressure!
Caleb 22
2007 LBZ CCSB S475/stock Wehrli Twin Turbo Kit/Suncoast Built by Dmitri Millard
EFI Live DSP5 by Duramaxtuner.com
5" DE, rerouted, debadged, demolded, 18X9 BMF Novakanes Stealth wrapped with 285/65/18 Nitto Trail Grappler MTs, 45 gallon transfer flow replacement tank, Amp power steps, All Season bulletproof trans/power steering line kit, Airdog II 165, Nicktane with Cat filter, Edge Insight CTS with pyro
Big thanks, Duramaxtuner.com & Willie @ Synthetic Motorsports
TakeEm is offline   Reply With Quote
