Boost fooler. Ppe valve - Chevy and GMC Duramax Diesel Forum
post #1 of 20 (permalink) Old 04-03-2013, 12:53 PM Thread Starter
Iv been looking into boost fools and valves for my lb7. But i cant seem to find my answer. So i know with dodges you have to have a boost fooler in order to see the benefit of the boost elbow ( which is basically the same thing as a boost valve on a chevy). The boost fooler tells the computer to allow more boost before defueling and the valve mechanically blocks the wastegate to create more boost. So does this go the same as dodges on chevys. Do i need a boost fooler or is there no defueling on the duramaxes at a certain psi. I have a bullydog programmer also (not by choice. Came with the truck). If i need boost fooling. Does this programmer do it. Again i have searched. Cant seem to find an answer to this. Thanks for any help
02 GMC lb7 4x4 2500, auto, ccsb, white, K&N CAI, 4in. tb exhaust SP, bully dog power pup programmer, PPE Boost valve, 108,000 miles. CA edition. Yuck!!
Wanted: intake horn upgrade, better fuel mileage.
01 Dodge 24 valve cummins 2500, 2wd, eclb, 6spd, HO, 1 ton suspension, S&B CAI, Edge EZ, Raptor 100 lift pump, big line kit, exhaust brake, 200,000 miles. 26.4 mpg highest i have ever had in a diesel, hand calculated.
roper23 is offline
post #2 of 20 (permalink) Old 04-03-2013, 01:02 PM
CRFmxracer's Avatar
not sure if the bullydog does that but what the ppe does is fool the wastegate into thinking the boost levels are lower than what they truely are so the wastegate doesnt open until later. its not electrical at all.
hope that answers your question?
1995 Chevy 6.5 4 inch exhaust, KYB Shocks Eagle Alloy 16x8 186s,BFGoodrich A/T 285s SOLD
2001 Blue RC/LB 2500HD
4" straight pipe, 4" Billscustomintake, PPE Boostvalve, TIS 535MB 20x12 on 305/50 420s, Debadged, Airdog 165, Autometer Cobalts, EfiLive with Starlite Diesel Tunes, ProFab Turbo Horn, 18% Tint, Recon tailgate lightbar, Recon Cablights, Sleeves.
Wishlist: smoked running+headlights, Blackout Performance trans, Color match ERRTHANG
CRFmxracer is offline
post #3 of 20 (permalink) Old 04-03-2013, 01:23 PM Thread Starter
I know thats what the boost valve does. But is there a electrical sensor that defuels the engine when it hits a certain pressure as a second safety besides the wastegate. Basically do i need an electronic boost fooler to allow the truck not to defuel at a higher pressure like on my 24 valve dodge.
roper23 is offline
post #4 of 20 (permalink) Old 04-03-2013, 01:26 PM
lddrew's Avatar
no you do not need that.
The boost increase valve and tuning will allow for more boost when it is needed.
I would highly recommend reevaluating your tuning situation and consider losing the bully dog
-Lee-
LBZ Crew - EFI - MBRP - Profab - Airdog
Raptor lined rockers and flares by me
my "build" thread
Raptor color match thread
ATP Trucks
lddrew is offline
post #5 of 20 (permalink) Old 04-03-2013, 01:32 PM Thread Starter
Ya. I definately have pondered getting rid of it. I only keep it at the lowest setting. But it definately doesnt fair as well as the others iv driven. But it came with truck. So just trying to gain efficiency as cheaply as possible. Hence the researching on the boost valve and intakehorn modifications. Thank you for the answer
roper23 is offline
post #6 of 20 (permalink) Old 04-03-2013, 01:36 PM
lddrew's Avatar
no worries man, enjoy the truck. and yeah as far as easy LB7 mods go definitely do BIV, look into intake horn, batmowheel if you so desire, and a downpipe
get rid of that emissions bullshit too when you upgrade tuning
Autocal from ATP (what I'm running) or Kory Willis at PPEi is what I would recommend highly as far as tuning goes.
Regards,
Lee
-Lee-
my "build" thread
ATP Trucks
lddrew is offline
post #7 of 20 (permalink) Old 04-03-2013, 02:31 PM Thread Starter
ya. I cut the CAT off. have looked into deleting or at least shutting off the egr and rerouting the pcv. I know that EFI you can shut it off, but that's pretty expensive. trying to talk a friend into going half and half on buying it since it comes with two trucks. how do you like Autocal, I have never even heard of that tuning program? thanks for the help.
roper23 is offline
post #8 of 20 (permalink) Old 04-03-2013, 02:34 PM
lddrew's Avatar
The Autocal is just one way to load EFI tunes onto your truck. I personally went with a pretuned ECM from ATP with a DSP5 +- 350 bucks all said and done. It was the most affordable option for me and I don't have major upgrades budgeted in the near future to need a handheld
Autocal tuning is+- 650 bucks
V2 +- is like 1100 or so with tuning, but you can use it on multiple trucks and with different tuners tunes.
My EGR is just blocked with a 11 dollar plate, and tuned out with Rob's tuning. PCV reroute is a good idea/
-Lee-
my "build" thread
ATP Trucks
lddrew is offline
post #9 of 20 (permalink) Old 04-03-2013, 03:34 PM Thread Starter
So you bought another ecm or sent them yours for 350?
roper23 is offline
post #10 of 20 (permalink) Old 04-03-2013, 04:02 PM
DIRTEEMAX's Avatar
No need to reroute Pcv on lb7 .. I have my EGR turned off and I have a plate for it but I haven't put it in but just shutting off the EGR in Efilive got rid of a shit ton of engine lights . I will soon install the plate though too . EFILIVE via Kory or Rob is the way to go . I live in Cali as well and I hope you have that cat or your gonna be ed come smog time . I bought a cat delete pipe with the flange for mine and a cat back exhaust with no muffler . That way I can remove the cat delete pipe and put the cat back in for the inspection .
2002 2500HD 4x4 ccsb
EFI live Idaho Rob tunes DSP5 opt stock,hv tow 25hp,lt tow 50hp,econ/street 75hp,performance 100hp
LBZ CP3 and regulator
4'' lift
Ultra Predators
Nitto Terra Grapplers
WHEN GUNS ARE OUTLAWED I'LL BE THE OUTLAW !!
DIRTEEMAX is offline
