PPE Hot +2, PPE Ported Fuel Rail Fitting, PPE High Idle, 5% window tint all around, AFE Stage 2 CAI with resonator plugged, 6" rcd lift and traction bars, 315 toyo open county m/t's black rock crawler rims, cowl induction hood, projector headlights with 6000k hid's, led tailights, 4" straight pipe turbo back to 6" single stack, BD diesel exhaust manifold, Kodiak sidewinder retractable steps, autometer boost trans and pyrometer gauges, Mag-Hytec transmission pan, banks big head wastegate, ppe boost valve and more.
Well if it does you are not going to feel a difference it just helps the rail recover from fuel loss. I installed this on my LLY and a shimmed FPRV & i still get the fuel limp codes and the only thing that will fix is a lift pump. I have everything else done on my truck except the pump and i have been taking it easy.
__________________ 2004.5 LLY,2500,CC,SB 4X4 LS,BLACK,
DANVILLE,68MM,STAGE2,2.6 CHARGER
PORTED & POLISHED HEAD'S
ARP HEAD STUDS,
DSP5,EFI TUNED BY Nick!
SUNCOAST STAGE IV W/1057,
AIRDOG II-165,
PORTED PPE FUEL RAIL FITTING,PPE RACE VALVE,
LOT'S MORE!
Instead of buying the fittings you can also drill them out
__________________ 2004.5 Chevy Silverado 2500HD Duramax LLY
J.T.
Shhh!!! Its taking a nap before pulling season starts!!!
11.93@ 109mph on 35's and with 4.10s EFI Live Tuned By Mark Broviak
2006 GMC 2500HD Duramax LLY
Banks intake, 5" inch MBRP exhaust, Fass 95, EGR deleted, PPE Race Fuel Valve, EFI Live tuned by Mark Broviak.
couldn't you just drill out your factory fittings and save 100 bucks? I don't mean to try and take any business from the vendors here but it looks like the same thing with a bigger hole???
__________________ 2003 CREW CAB CHEVY HD2500 LB7 DURAMAX
EFI LIVE W/ DSP2 SWITCH
PPE BOOST VALVE
SOCAL TRIPPIN OVERHEAD
AUTOMETER CARBON/FIBER GAUGES
ROUGH COUNTRY 6'' LIFT
MOTO METAL 956 17X9
PRO COMP XTREME A/T 35's
