Old 01-27-2009, 07:29 PM   eBay Motors  #21 (permalink)
WisconsinHick1's Avatar
Originally Posted by Dmax15 View Post
125 thousandths is what I've been told for the drivers side and for the passenger side its 60 thousandths with a single CP3 or 90 for dual CP3's.
I didn't know they made drill bits that small.
WHATS EFI LIVE????
Red bow ties88 hates regular people that have to stoop to turning on a knob to change tunes.
Old 01-27-2009, 07:30 PM   eBay Motors  #22 (permalink)
6.6 dmax's Avatar
is it okay if you do them both the same size?
2004 Chevy Silverado 2500HD Duramax LB7
Two tone, Red and Charcoal Grey
PPE Hot +2, PPE Ported Fuel Rail Fitting, PPE High Idle, 5% window tint all around, AFE Stage 2 CAI with resonator plugged, 6" rcd lift and traction bars, 315 toyo open county m/t's black rock crawler rims, cowl induction hood, projector headlights with 6000k hid's, led tailights, 4" straight pipe turbo back to 6" single stack, BD diesel exhaust manifold, Kodiak sidewinder retractable steps, autometer boost trans and pyrometer gauges, Mag-Hytec transmission pan, banks big head wastegate, ppe boost valve and more.
6.6 dmax is offline   Reply With Quote
Old 01-27-2009, 07:33 PM   eBay Motors  #23 (permalink)
duramaxxin73's Avatar
I don't know I've been told by some that if you drill the passenger side the same as the drivers side that you stand a good chance of losing rail pressure faster. Thats what I read over at DP
2004.5 Chevy Silverado 2500HD Duramax LLY
J.T.
Shhh!!! Its taking a nap before pulling season starts!!!
11.93@ 109mph on 35's and with 4.10s
EFI Live Tuned By Mark Broviak
2006 GMC 2500HD Duramax LLY
Banks intake, 5" inch MBRP exhaust, Fass 95, EGR deleted, PPE Race Fuel Valve, EFI Live tuned by Mark Broviak.
duramaxxin73 is offline   Reply With Quote
Old 01-27-2009, 07:34 PM   eBay Motors  #24 (permalink)
Super Diesel's Avatar
Yes. Same size is fine. This was one of my first steps back in early 05 in flowing more fuel. The reason some say you lose rail pressure is the placement of the sensor. It's on the junction block on the LB7s (pressure is backed up in the feed lines) instead of the rail like the LLY and newer. It gives you more of an actual reading now that there is no backed up pressure.
02 GMC 4D 4WD DUALLY (WHITE BUFFALO)
GT4202 and Dual Fueler from PPE w/my moded LBZ CP3s.
Tune by Tony at RIDGE RUNNER & EFI live.
Trans is a Mike L. special with a SC1057.
Heads, Pistons, and balancing by Guy at SoCal.
Carrillo rods.
A1 & ARP studs.
Injects by Kerma.
And some massaging and machining from me. Lots of other little stuff.
Designer of SD products. Constaintly imitated but never duplicated.
Super Diesel is offline   Reply With Quote
Old 01-27-2009, 07:35 PM   eBay Motors  #25 (permalink)
Kratos
DMAXchris's Avatar
Is it plausible to do it ourselves?
06 Chevy LBZ/Allison 4x4 EFILive & DSP5, Suncoast IV w/1054, Suncoast Tcase brace, MA pump rub fix, PPE lift pump, AEM Intake, shimmed fprv, ported rail fittings, 4"-5" Grandrock/MBRP, torsion bolts removed, 4" drop shackles, stock turbo, stock wheels, Autometer GS boost/pyro, Aeroforce scangauge, PPE sleeves, Cognito pitman/idler braces, 8k HIDs, Recon LED tails & smoked 3rd brake, Pioneer DVD, 98,000 miles and counting
12.60 @ 105.41 mph
#15---Top 25 Fastest Stock Duramax's
Keystone 8 Luggers
Videos
DMAXchris is offline   Reply With Quote
Old 01-27-2009, 07:37 PM   eBay Motors  #26 (permalink)
If it is where can I find the small @$$ drill bits?
WHATS EFI LIVE????
Old 01-27-2009, 07:45 PM   eBay Motors  #27 (permalink)
03-GMC's Avatar
How much does a moded regulator valve run? Also how much do the rail fittings run?
2003 GMC LB7 CC/SB
EFI by IdahoRob, SCIII W/ML Precision Converter by Trent Nell, UL-II Gauges, 5" Straight Pipe, PPE Boost Valve, AFE Intake, and FASS Fuel Pump (150GPH), Modded Intake Horn
1/4 mile time 13.2, 454 RWHP
565 RWHP on some spray
-Derek
Coming Soon
SDP Twin Kit, more gauges and some more Tuning from IdahoRob
GotSomePerformance
03-GMC is offline   Reply With Quote
Old 01-27-2009, 07:50 PM   eBay Motors  #28 (permalink)
Dmax15's Avatar
Get an index drill bit set, not sure where to find them.
Screamin Diesel Performance- Scott
01-04 LB7 compound twin turbo kits
www.ScreaminDieselPerformance.com
2002 GMC LB7
Cognito tie rods/braces, SC stage IV, MITUSA pump, ProFab manifolds/up pipes, EFI live by IdahoRob
12.34 @ 108.7mph with Twins!
Dmax15 is offline   Reply With Quote
Old 01-27-2009, 07:57 PM   eBay Motors  #29 (permalink)
Is he talking about the pressure regulator on on the cp3?
J.T.
Old 01-27-2009, 08:05 PM   eBay Motors  #30 (permalink)
03-GMC's Avatar
Im talking abot the one that super diesel talks about on page 1 of this thread. This is all new to me its the first i've heard of any of this.
2003 GMC LB7 CC/SB
-Derek
Coming Soon
GotSomePerformance
