well if your towing on the flats you should be ok then with the performance setting but in the hills i would drop it forsure but thats up to you..
i have a quadzilla commander shitting at the shop here that has everything you need to hook up your gauges,like boost,egts,oil temp or tranny temp(i forget the rest)..it needs a pod but i would sell for $250(shipped)brandnew(new they are $370 or so)..its a stand alone setup so it will work by itself.
__________________ James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
*Suncoast Stage IV w/ATS Five Star Torque Convertor w/Co-Pilot. 7" Mitre cut Stack w/ Hush Power muffler, tie rod sleeves and center link, Fass 200, Modded dual DP LBZ cp3's, E-Locker, 60% nozzles, Danville Performance Stage 2 65mm Turbo. *
11.93@ 109mph on 35's EFI Live Tuned By Mark Broviak
2006 Chevy Silverado 2500HD Duramax LBZ
aEm intake, MBRP 5" exhaust, no tuning for now!!
The gauges and the normal set up is in my 04.5 cummins. It needs tires so I am using my duramax for this haul. I just havnt had the extra $$$ to get the Dmax set up right. Thats why I wanted yalls opinions on what setting. I used the Dmax as my welding rig not a hauler. If I had any xtra $$$ I would be interested in your quad, but I am straped and leaving Sun for CA.
__________________ 02 GMC Cab n Chasis 3500 6spd manual
All Stock...need some stuff
Run it on the 40hp setting. If you do run on the 75hp setting make sure you keep your RPM's up. Dont let it lug down, thats when you will get it hot. Higher RPM's means more boost, that will keep it cool.
04 Dmax753rwhp/11.8@117 #2 only full street trim on 22"s A6K, MMLMM EFI DSP5 tuned, MMLMM TCM tune, SoCal stage 2 heads, SoCal dampner, SoCal hold downs, ATS dual cp3's, 60% nozzles, ATS cam, Crower rods, cut Mahle pistons, ATS manifolds/up-pipes, ATS extreme Billet w Co-pilot, MikeL cooler, suncoast brace, PPE billet tank pick-up, FASS, Caltracs, Cognitos, Centerlink, 5100 Bilsteins
NWTDiesel's truck is NASTY. Blacked out miles of road down I25 and beat up on 505Outlawz 11.5 car from a roll. I was trying to keep up but my Cummins is slow
Good times lastnight. That truck is fast as s@#t and I knew that I would get walked but I still wanted to try.
Joe
03 SVT Lightning
Does a Banks make it run hot as well? I will be running about 20K GCW with my truck and was talking to someone about buying his Banks...... but I dont want to run hot...?
__________________ 2004 2500HD Crew Cab Short Bed 4x4
Banks Six Gun with Speedloader
K&N air filter
B&W Turnover Ball, self installed
Intake Horn wallered out
265/75R 16 BFG AT 10ply
7in Touchscreen DVD player to entertain the kids
Hauling beast, brought 30,000 GCW down from PA
more to come of course.....
Hey guys....load fell through at last minute. So there goes the money I was really needing to pay the bills, but oh well. So I wont be hauling anything and wont be burning the truck up...lol. Thanks for all the input guys.
I run the BDTD and for 160 bucks you can get the pyro (egt's) cable. The BDTD has all the guages you can need. Boost, Pyro, Trans, etc...And i tow a 28 ft. Baja speed boat on performance and i never get hot. You should be fine towing on performance.
__________________ Sean
03 black LB7
PPE tuned
"I never could stay sober on the Corpus Christi bay..."
Everybody keeps talking about keeping the tuner turned down while towing. I don't understand. I keep my six-gun on 6 at all times, and now my boat is only about 4500 lbs, but I only see egts at about 800 degrees at 65 and peak at 950 when going up hill or picking up speed. Banks claims 155 hp and 350 lb/ft at level 6 on the lb7 engine. Of course, I don't pin it all the time, and drive conservatively. So what benefit do you get with a lower tune setting? For me, I see better numbers on the higher tunes.
__________________ 2004 lb7 cc 8 ft bed
Bank's Six Gun with speed loader
AEM dry filter
4 inch Banks monster exhaust
2 inch leveling kit on front
Banks 2 gauge cluster
Ported intake horn
I LOVE ME SOME DMAX!!!
Heat soak.
The benifit from a lower hp tune, is well, lower everything. lower fuel etc.
I dont understand when people tow on high levels just do to it. I have a built trans and I tow stock, im not in a hurry to get where im going, but thats just me.
__________________ Brian
06 LBZ Slightly tuned
20" monsters on 285's
Lowered
Magnaflow
HTT 66/71
Tuned by MMLMM www.mmdieselperformance.com 11.99 is 1 second faster than 12.0
