Closed Thread
Old 03-14-2009, 09:47 AM   eBay Motors   #1 (permalink)
formula455
formula455's Avatar
LB7 Turbo mouthpeice mod
Had a few hours to burn the other day so I did the turbo mouth peice mod, It really does help, boost comes in sooner and the driveability is better, I took me about 3 hours start to finish, make sure you get a gasket before you start, I didnt and had to make one, If you have been thinking about doing this mod, DO IT you will be suprised
2003 cc 2500 duramax / allison
130000 miles
mods- quadzilla steath 2 set on 110 hp, magnaflow 4" S&B freshair intake, ppe boost valve, autometer boost and egt pillar pod,
formula455 is offline
Old 03-14-2009, 11:30 AM   eBay Motors   #2 (permalink)
stoney
I agree i just put this mod on my truck and definitely a noticeable difference.
2003 3500 ext. cab drw
5in. straight piped
brute force intake
diablosport predator
modded intake horn (thanks Freddy@diamond shocks)
51000 mi.
stoney is offline
Old 03-14-2009, 11:33 AM   eBay Motors   #3 (permalink)
Dmax15
Dmax15's Avatar
Yep, it helps a little and gives it more of a whistle through the intake. Its an easy mod to do yourself and doesn't take long at all.
2002 GMC LB7
EFI live tuning from IdahoRob
http://www.atptrucks.com
12.34 @ 108.7mph
Dmax15 is online now
Old 03-14-2009, 11:35 AM   eBay Motors   #4 (permalink)
Hudsongeneral
Hudsongeneral's Avatar
Is this a bolt kit or is there any milling involved? Does anyone know of a link that explains how its done?
Hudsongeneral is offline
Old 03-14-2009, 11:37 AM   eBay Motors   #5 (permalink)
Hudsongeneral
That was supposed to read "is this a bolt on KIT....." damn keyboard
Old 03-14-2009, 11:44 AM   eBay Motors   #6 (permalink)
Dmax15
Dmax15's Avatar
You can actually take your stock intake horn and port it out, the majority of the benefit comes from the turbo side of the horn. Its easy to see where you will get gains from when you take it off and look at the inside. Just take the intake off then the three bolts that hold it onto the turbo.
2002 GMC LB7
12.34 @ 108.7mph
Old 03-14-2009, 11:47 AM   eBay Motors   #7 (permalink)
stoney
pm timespentsearching on here if you don't want to do it yourself. he has an exchange program going and it worked well for me.
5in. straight piped
brute force intake
51000 mi.
stoney is offline
Old 03-14-2009, 11:49 AM   eBay Motors   #8 (permalink)
HPaddict
timespentsearching had a thread on here not to long ago about this and I believe he was doing these for a fee and exchange of your existing MP, maybe he'll chime in on this.
2002 Chevy LB7 3500 CC DRW LS, white, debadged, spray in bedliner, B&W Turnover ball GN, 235/85/16 AT's, AFE Stage 2 CAI w/ resonator removed and plugged, PPE Boost increase valve, MBRP 4" downpipe back exhaust, AutoMeter Ultralight gauges in A-pillar, Injectors replaced at 140,460 (2nd time)
HPaddict is offline
Old 04-07-2009, 09:08 PM   eBay Motors   #9 (permalink)
T.P.D-03lb7
T.P.D-03lb7's Avatar
I read this whole page 5 times and still don't understand what you guys did? Is there anyway you can show some type of picture and explain differently.. because i want a piece of what you guys did.
thank you-
Black 03lb7 extended shortbox-
EFI Live dsp5, Suncoast stg 4,
ppe boost valve , K&N cai
straight pipe, 6" stack
4"lift turnin 33'
turbo intake horn mod
"Black smoke dont
mean it broke!"
T.P.D-03lb7 is offline
Old 04-07-2009, 09:13 PM   eBay Motors   #10 (permalink)
timespentsearching
timespentsearching's Avatar
yep im still doing it guys, i ahve i think 20 people on my list right now. i have 4 horn and am trying ot get them aorund as fast as i can but waiting to get them back is what takes the longest.
as for the different here look.
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
timespentsearching is offline
Closed Thread
