Old 05-14-2009, 02:35 PM   eBay Motors   #1 (permalink)
Pope54x
Banks Wastegate question?
I have a 2004 Duramax with a Banks Bighead and PPE Boost valve and im only boosting 20 PSI what can I do to get more boost? I blew my turbo and had a guy put it on when he changed the turbo when I got the truck back it boosted 18 PSI then I put the PPE boost valve on and now it boost 20PSI any suggestions?
2004 Duramax Dually LB7 Stealth 2, Banks Ram Air with the Super Scoop, GM Perfromance Exhaust, Banks Big Head Wastegate, PPE Boost Increase Valve. More goodies to come!
Pope54x is offline   Reply With Quote
Old 05-14-2009, 04:11 PM   eBay Motors   #2 (permalink)
KoDracing
KoDracing's Avatar
Mine on stock settings is boosting 24-26, with the same set up??
KoDracing
TulsaCycleSupply.com
03 LB7
6" Fabtech Lift
Quadzilla Stealth 2
Big Head Wastegate
4" Straight Pipe with 5" Tip
K&N Cold Air Intake
PPE Boost Valve
Mag-Hytec rear end cover
KoDracing is offline   Reply With Quote
Old 05-14-2009, 04:14 PM   eBay Motors   #3 (permalink)
WisconsinHick1
WisconsinHick1's Avatar
Take one or the other off having both wont do anything for you. If you take the PPE boost valve off then you can use the Banks to adjust the PSI level. Do you have a programmer?
A FEW MINOR UPGRADES
Tuned by MMLMM
SC V
Old 05-14-2009, 06:35 PM   eBay Motors   #4 (permalink)
Pope54x
Ya a stealth 2
Old 05-14-2009, 06:39 PM   eBay Motors   #5 (permalink)
WisconsinHick1
Oh sorry I didn't see that in your sig. I would take off the PPE valve and start adjust your banks until you start to see a rise in pressure.
Tuned by MMLMM
SC V
Old 05-14-2009, 06:49 PM   eBay Motors   #6 (permalink)
Pope54x
Ill try that thanks man im hopin to see a little more power out of the Ram Air system.
Old 05-14-2009, 06:57 PM   eBay Motors   #7 (permalink)
WisconsinHick1
Not a problem I have the Banks Big head and Im seeing 30+ so just do some adjusting and test drive it and see where your at if you drop psi crank it the other way and see what happens.
Tuned by MMLMM
SC V
Old 05-16-2009, 08:39 PM   eBay Motors   #8 (permalink)
DuraTitus
DuraTitus's Avatar
Hey man I have a Banks Big Head and my cousin has the PPE valve and we are both seeing 29-30 psi. Do you have a mechanical guage?
Pickup: 2002 Chevrolet 2500HD Duramax/Allison Reg. Cab with
Royal Utility bed and racks
Intake: Stock with KN Filter
Transmission: Stock
Mileage: 151,000 No Rust
DuraTitus is offline   Reply With Quote
Old 05-16-2009, 08:47 PM   eBay Motors   #9 (permalink)
2fast4u
was the big head thing a PITA to install?
2001 GMC D-Max extra-cab short bed 4x4 177,500 miles
Edge wit attitude(with hot unlock), Stealth 2 (215hp) 4" silverline, modified air box, ppe boost valve, new injectors and cp3, raptor 150 and suncoast IV installed by big dipper!
With some other non performance mumbo jumbo
2fast4u is offline   Reply With Quote
Old 05-17-2009, 08:35 AM   eBay Motors   #10 (permalink)
topherstrux
topherstrux's Avatar
Seeing about 24 psi here. 26 in the winter. Now that summer is coming I think it will drop a little due to the friggin Texas heat!
2004 lb7 cc 8 ft bed
Bank's Six Gun with speed loader
AEM dry filter
4 inch Banks monster exhaust
2 inch leveling kit on front
Banks 2 gauge cluster
Ported intake horn
I LOVE ME SOME DMAX!!!
topherstrux is offline   Reply With Quote
